Rocker arm problem?
Old Nov 25, 2006 | 09:49 AM
ls2formula's Avatar
Default Rocker arm problem?Pic inside!
My car has been making a tapping/knocking sound for a while.I figured I would check the pushrods and rockers and this is what I found.Any ideas on what caused this and should I worry about it.I have a LS2 402 with AFR heads and a .579 244 248 cam
Old Nov 26, 2006 | 12:27 AM
Mean Green z28's Avatar
Looks like the rocker body is wearing out by the roller being up against it. Does the roller have slack on it sideways? Is it only on this rocker? If so, maybe faulty rocker.
Also, check your valve tips while you're at it if you haven't done it already...
https://ls1tech.com/forums/generation-iii-internal-engine/611867-afr-s-resolution-valve-tip-issue.html
Old Nov 27, 2006 | 08:30 AM
ls2formula's Avatar
https://ls1tech.com/forums/showthread.php?t=611867
The valve tips are fine.Has anyone else had this problem?I guess this is why people use the stock rockers.
Old Nov 27, 2006 | 10:50 AM
White_Hawk's Avatar
Is that a Harlan Sharpe rocker? The Grand Prix guys are having the same issue with the 1.9 rockers sold from Intense Racing - they are repacked Harlan Sharpes..
-Geoff
Old Nov 27, 2006 | 10:55 AM
ls2formula's Avatar
-Geoff
Yes Harlan Sharp.It happen on 4 of the rockers.btw this is not what was causing the tapping sound.I put the stock rockers on last night.
Old Nov 27, 2006 | 04:58 PM
Dave88z's Avatar
Were those rockers "e-bay specials" or new from a sponser?
Old Nov 27, 2006 | 07:26 PM
ls2formula's Avatar
New from a sponser about a year and half ago.
Old Nov 28, 2006 | 10:02 PM
Well you're probably having a lifter issue. Does the sound change with oil temp? Stock rockers are just fine, we've been 9's hundreds of times (same set) with no issues.
Old Nov 30, 2006 | 05:38 PM
98Z28CobraKiller's Avatar
Restricted User
Told ya that the stokers were fine.
Did you check the lifters yet?
Old Nov 30, 2006 | 06:59 PM
GuitsBoy's Avatar
possible oiling issue?
Old Dec 8, 2006 | 12:01 PM
ls2formula's Avatar
I called Harland Sharp and told them about my problem.They told me to send back the bad rockers and they would replace them. They told me the new ones have an extra oiling hole on them.
Its nice to see a company stand behind an aftermarket performance part.
Old Dec 10, 2006 | 07:29 PM
402 Dragon's Avatar
Good to hear Harland Sharp is standing behind them. I have the same rockers, will I be able to see the extra oiling hole?
