Precision Race Components Ported 6.2L Cylinder Heads Almost Ready!
Old 01-13-2007, 07:52 AM
  #161
LS1LT1CAM's Avatar
Originally Posted by dhdenney
Jesel. Don't have anything else yet.
WHAT ABOUT THE VALVES ARE THET STAINLESS AND ARE THE SRINGS GOOD TO 700 LIFTBAND 7500 RPM. HAVE CAM, BIG ONE, CAR IS GOING TO BE MANY RACED BUT DRIVEN ON THE WEEKENDS. HOPING TO MAKE 550 TO 600 TO TIRE ON NUT THEN ADD SQEEZE
Old 01-13-2007, 08:59 AM
  #162
dhdenney's Avatar
You'll probably want titanium for that but I don't know of any shelf items yet.
Old 01-13-2007, 11:46 AM
  #163
LS1LT1CAM's Avatar
WHAT DOES YOUR CAR WIEGH GOT MY 94 CAM WITH CARBED 355 CU AND 4500 WITH GLIDE AND 150 SQUEEZE TO GO 10.20S 3270 CAR And drive
Old 01-13-2007, 01:30 PM
  #164
03 BUSA's Avatar
Being told they will be available at the end of next week. They got the program up and running. Just making sure all is perfect before shipping to us.
Old 01-13-2007, 10:42 PM
  #165
blackbelt's Avatar
Originally Posted by RyneZ06
why dont you change your screenname to "Mr. 2cents", because on alot of threads you are giving just that....
Dear god ryne...you should just change your name to **** stirer. lol
Old 01-16-2007, 10:08 PM
  #166
dhdenney's Avatar
Have we heard anything else yet? I'd bite the bullet if these were ready.
Old 01-17-2007, 05:57 AM
  #167
V6 Bird's Avatar
Originally Posted by Forteen3GT
We all can assume the stock valves are for shortblocks with a 4.060 bore or smaller and the 2.18/1.60 valves are for engines with a 4.1 or larger bore. Have you considered the potential issues with PTV/valve shrouding by using the larger valved head on a 4.0 or 4.030 bore? It would be ill advised for someone to purchase these heads and not know what piston combination they can put on without potential failures. Just wonderin
offset the heads on the block .050 problem solved.
Old 01-17-2007, 07:38 AM
  #168
WizeAss's Avatar
is that possible?
Old 01-17-2007, 09:30 AM
  #169
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Guys I've been working on the head a little bit the last couple of days. I hope to have it finished up very shortly. The thing is I won't let it leave until it's exactly what I want it to be. I've been working with the head & the intake as a combo & we're currently making some tweaks to help the head out a little bit. I have stock valves, 2.170 & 2.180 valves being produced. I've also been talking with several different valve manuf. looking for hollow stem valves to save some weight.
Jason
Texas Speed
www.texas-speed.com
806.866.0734
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 01-17-2007, 10:00 AM
  #170
dame's Avatar
Jason
Texas Speed
www.texas-speed.com
806.866.0734
Is texas speed going to be the first shop to actually give out intake runner size on their product? Or will this request be ignored like the others? I'm trying to understand why this information is so top secret. Especially since potential customers are asking the question
Old 01-17-2007, 01:25 PM
  #171
dhdenney's Avatar
This is just a guess because I have zero info to back this up but my guess is the intake runner size is stock. (Those that won't disclose.)
Old 01-17-2007, 01:57 PM
  #172
dame's Avatar
hmmmmm that I never thought about
Old 01-17-2007, 04:49 PM
  #173
WizeAss's Avatar
likely the runner is big enough for the intake and porting it further wouldnt help flow.
Old 01-17-2007, 07:01 PM
  #174
dhdenney's Avatar
Kinda what I was thinking. These ported heads are likely exhaust work and probably just some cleanup on intake side. (Just a guess, no one shoot me.)
Old 01-19-2007, 05:13 AM
  #175
cws T/A's Avatar
We're nearly finished tweaking the 6.2l cnc program for you guys wanting to tryout the rectangle port heads on your strokers! We spent a lot of time developing the port & setting the valve height up for extra p/v while still flowing BIG AIR! These cylinder heads will be available with either stock 2.160"/1.59" valves, or the stage 2 2.180"/1.6x" valves. Either option will be shipping with our new valve spring option. With this setup I feel these heads will support about .630" lift or so. I'll test a few different setups to confirm this, but that's my guess...
Here's some flow data from the stock valve port:
.200 156 114
.300 226 154
.400 287 187
.500 325 207
.600 351 229
.650 357 234
This was flowed on a 4.030" bore plate. The port was designed to work well on 402/408/418 mid-size bore stroker applications. This cylinder head was designed for bore applications that the common stroker owner runs.
I hope to begin shipping these things late next week! I'll keep everyone posted with more details & dyno results as they become available.
THIS FLOW DATA IS ON A 4.030" BORE PLATE & USING NO EXHAUST PIPE!
Compare these flow numbers to others flowed on much larger bores...
What will the finished combustion chamber cc be ?
How much can the L92's be milled before Intake manifold fitment problems or loss of flow ?
Old 01-19-2007, 08:47 AM
  #176
dame's Avatar
One last question from me...... Is there any chance that you could flow a set of these with an L76 attached and give us those numbers?
Old 01-19-2007, 09:02 AM
  #177
PediDr2's Avatar
If You're gonna flow intakes as well how about an L92 intake/head combo for us truck guys
Old 01-23-2007, 03:21 PM
  #178
jasond26's Avatar
Any closer to having these heads ready?
Old 01-23-2007, 04:42 PM
  #179
tlaselva's Avatar
First they tease us, then they leave us dangling . . .
Old 01-23-2007, 09:05 PM
  #180
03 BUSA's Avatar
They had some issues with the first digitalizing of the CNC product and had to resend it out. Being told within 1-2 weeks, should be good to go. Right now their flow numbers were around 340 and they will not sell till the 360 is hit. So I commend them for that, I have been waiting on these heads since dec 8th, and they have been paid for so just be patient and they will deliver a kick *** product.
Quick Reply: Precision Race Components Ported 6.2L Cylinder Heads Almost Ready!
