Milling the L92 heads
Old Nov 29, 2006 | 07:12 PM
bigbls1's Avatar
Default Milling the L92 heads
I think the L92 head comes as a 69cc how much would you have to mill them to get them down to a LS2 cylinder head cc on factory LS2 pistons and head gaskets? Thanks for your help.
Old Nov 29, 2006 | 07:15 PM
Quik's Avatar
i beleive .030 off and a .040 gassket wil lput you close
Old Nov 29, 2006 | 07:16 PM
JBM's Avatar
JBM
.030? A good bit.
Old Nov 29, 2006 | 07:21 PM
See5's Avatar
I wonder what the ~.040 it takes to get to ~60cc will do to the intake fit? I can be an issue on LS1/6s and FAST intakes bottoming out and mismatching ports.
Old Nov 29, 2006 | 07:43 PM
RGKSR's Avatar
Default 1cc - .006?
I thought that 1cc = .006 milled off.
The complete L76 intake was delivered today and I should have my L92 heads this week and was planning on .036 from the heads and a .040 gasket. This should give me 11.125 (approx) on a 402.
With the pistons .010 above the block and the .040 gaskets I hope to have a good quench area. Until I get the final cam specs I can't determine the DCR but it should be around 8.4.
All I need to do is get through the next week (hunting) and then I can start the engine swap.
Bob K.
