Is this 6.0L a blem block?
On the LS2 they are there but were not drilled out (ie no oil flows threw them). On the Vortec Max (L76) or any other DOD Gen IV they will be functional (IE if you don't cap them off oil will flow through them and throw off your oil pressure reading). Damn shame you can't hook up a pump to see if it flows or not.
The thing I hate the most is the page is blocked at work so I can't see the images until I get home.
Sounds like the L76 block, and that is about the only difference between the LS2 and L76 block.
It's a shame it wasn't a 4.065" bore L92 block (then you could put together a 414).
I got one in to sleeve about a couple of years ago. I thought was some sort of factory prototype piece. A short time later I found out it was a production truck casting.
The lack of breather holes causes a horsepower loss at high rpm (roughly 20 hp according to one of my NHRA stock eliminator customers) unless you run a good dry sump system capable of pulling a vacuum in the pan in which case there is no loss in power - tested by one of my shop customers on his dyno.
I have sleeved a good number of these blocks for big inch applications. There is one casting number 12569513 5.3 L that has non siameesed Gen III cylinder walls making it unsuitable for dry sleeving. I have not run across a 6 L block casting with non siameesed Gen III cylinder walls.
Steve
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
