Life in a forged daily driver...
I had a ported Eaton 2003 Cobra. It was very nice to drive around with 500rwhp.
I'm going the other way... I want some cam lope now.Drivability is all in the tune apparently... If It sucks... well then I'll put up w/ it until I can build my 416 L92 based motor one day.
Well that is partially true... BUT, there is only so much that "tuning" can do for you when cam overlap exceeds 58 degrees (@ .006), for example... As overlap increases higher and higher idle quality and low-rpm driving suffers. Sure there are tricks to work around it, keep raising the RPM level until you can get idle under control, and/or go to SD... and if the cam is really wild you can ditch it all and run in open-loop... many here do...
I am on my sixth cam (mild to wild, back to mild) and have done the supercharger. There are compromises to each.
Driving a car once or twice is not living with and this thread is about daily driving your ride... in traffic, in the parking lot, five to seven days a week...
What has the intake got to do with high overlap cams (58* or so and higher) affecting idle and low-rpm driving???
I am using a FAST 90/90 setup now but with a ZO6(2002) cam and idle/low-rpm driving is as good as stock... a huge differnce compared to the 232/236 XE-R cam I had...
If you hit the searches hard enough (not just here) there are several 4" strokes burning/using oil... Some do, some do not... I have to assume that depending on how well everything seats some oil use is not the end of the world. I would like to know if a stroker does use oil how much is too much, 1qt every 3000 miles, 2qt every 3000 miles, ...etc...???
Unfortunately people guard this information, like it is a dirty little secret they do not want to admit to or let out... when many of us could greatly benefit from their experiences...
$3000-4000!!!!
That is almost the price of a SDPC 402...
