Life in a forged daily driver...
Long stroke with short sleeves....100% guaranteed, no question about it, pure fact that it contributes heavily to massive oil burning. My engine is a perfect example.
If bore was than every one of them would have problems. Now if a builder ***** up the ring set, well then that builder will **** up any engine on earth and it'll burn oil no matter what.
So its the stroke/sleeve length.....FIRST...because even the best engine builder on earth can't help that problem, its a mechanical problem.
Then it goes to the builder..........SECOND...starting with the decision to not use a long stroke with a short sleeve in the first place, than just simply building the damn thing properly.
A properly built engine with a short enough stroke so the stroke/sleeve length issue is a NON-issue, there will be no oil burning from blowing by the rings, period. My friends 3 1/2 year old 422ci making 535 RWHP N/A and 850 RWHP (on spray) prooves that, and it helps that it was also built by someone who REALLY, TRULY knows how to build an engine properly. Not some cheezeball shop that makes 4 good ones, then one that blows up and they don't cover it, than they build one that runs low 10's and everyone says, Oh, they're the best shop now", than in a month they go out of business. So the builder is where it all starts, but noone can over-come the long stroke/short sleeve problem.
Other bad oil burning comes from bad valve seals in the heads, which I also had after my heads were 4+ years old. Besides oil leaks in the system (gaskets, lines, oil pan, etc) thats pretty much it for BAD oil burning problems.
The longer sleeves that Darton just made are 5.800" long, so even a 4.125 stroke is considered short and the oil burning will not happen anymore, at least not from the stroke/short sleeve issue. Your builder will have to **** up to have blow by. Or a abd tune in the beginning that washed the rings and they never seat, which also happened to my first engine.
Its so simple
I've been thinking about my next engine after this one and most likely it will be a 422ci iron block. 4.030 bore, 4.125 stroke, 6.200 rods. I've read up on them a lot on here and listened what to Sled28 has posted. He's built plenty of long stoke motors that don't have oil consumption problems. Granted with the longer rod, you now have less of a piston, because the pins are higher up.
https://ls1tech.com/forums/generation-iv-internal-engine/586580-4-1-4-125-stroke-possible-stock-ls2-block.html
Thread about long stroke motors
https://ls1tech.com/forums/showthread.php?t=586580
No matter what combo of crank and rod you use, if the piston is almost coming out the bottom of the sleeve, thats the oil burning culprit.
Oh, BTW....Sled28 built my engine. Besides the oil burning, he built a great engine as far as I'm concerned, reliable and staying together-wise.
Even with all the good and bad experiences/examples from this thread I am pretty sure this May I will end up with a 402 (my AFR205s and a small cam...) in my C5....
Its like we, as pilots say, sometimes the crash happens before the pilots even show up to the airport because of a bad decision to fly that day.........an engine can have an oil burning problem before the engine is even put together because of bad decisions.
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Had a JPR forged motor for a couple years, had oil consumption.
As far as daily driving, and this opinion is after 2 forged motors and 5 different tuners, I believe a LOT of it has to do with the tune.
My friend has a 422ci thats 3 years old and still burns nothing, it was built properly.
