Life in a forged daily driver...
If a builder chooses a shitty machinist, than that builder fucked up the build.
As always, my previous post was not understood. So, here goes again. A builder must start an engine build way before the parts are there and way before a tool is ever touched. Using a good machinist is perhaps the most important part of a build.
PERIOD
Didn't my pilot analogy make sense?
The engine now has about 3500 miles on it and was carefully broken in. I am not a neophyte when it comes to performance motors or cars. I have built several cars from the ground up and assembled more than a few motors making roughly the same power as this SLP402.
My hp numbers are good, even my highway mileage at 75mph is 26-28mpg.
BUT... I do not like the apparent piston slap and I really don't like going through a quart of 10-30 M1 every 750 miles!! The cars sounds like a bloody diesel EVEN AFTER IT IS WARMED UP. When accelerating up a hill in 6th it really sounds like a diesel. This is not detonation. I have HP Tuner, no knock recorded whatsoever. I can increase the timing and induce minor knock above 23-24 degrees advance WOT so I know it is not a faulty knock sensor.
I am inclined to agree that the 4" stroke really exposes a lot of piston skirt which makes sense that this would aggravate piston slap. A factory LS7 short block is sure tempting. I would probably seriously consider this if changing out these engines wasn't such a PITA. A good friend of mine has a '07 ZO6. His 4" stroke forged engine is smooth as silk. I am royally bummed that mine is not. For the $$ I should've just bought a new Z, but because a valve spring broke at 78,000 miles and toasted my engine my options were somewhat limited. I thought building a C6ZO6 equivalent with my C5Z made sense. My car still looks like the day I drove it off the showroom floor. I love the power, but it burns oil like and old farm truck and doesn't sound much better except at WOT (which is nothing short of fabulous!)
Would going to 50wt oil help? Living in San Jose, CA I don't have sub zero startup concerns. I know not to push a cold engine and know that doing so with heavy oil can blow a filter right off the block. I always used 50 wt Valvoline in my 69 L88. By the way, the factory 427 L88 made virtually the same rwhp and used a lot less oil even with its forged pistons.
Informed comments would be greatly appreciated!
Chuck
Anyhow, I'm not saying he's wrong. But in a way, he's worse than wrong. He's not even wrong.
Quickin: Funny you should mention Mike Norris as his patience kept me from trying to get too crazy with my old H/C combo...
I usually get flamed for saying this; get the best heads, intake, and headers you can and then go with the milder cam. People rely too much on the cam to get their power. Just my opinion...
