Life in a forged daily driver...
Old Dec 13, 2006 | 09:23 AM
SideStep's Avatar
Question Life in a forged daily driver...
Any issues with daily driving a forged motor, say 100 miles a day...???
-longevity?
-oil use?
Old Dec 13, 2006 | 10:09 AM
sprayjunkie's Avatar
If assembled properly and the machine work is done right, it should last a good long time and use no more oil than stock.
Old Dec 14, 2006 | 01:12 AM
Tom@SpeedInc's Avatar
Driven my 402 7000 miles last summer, used bit of oil, definatly run little extra compression and use a milder cam, would have rather run something around 230/230 112+2 XER lobes with 11.0 SCR for daily driver, I went with XFI lobe cam, springs are holding up well.
Old Dec 14, 2006 | 01:18 AM
TWISTEDTA's Avatar
Drive's great but does use oil.
Old Dec 14, 2006 | 04:26 AM
jfman's Avatar
Terminators came stock with Manley rods and pistons...
Old Dec 14, 2006 | 12:01 PM
SideStep's Avatar
What???
Old Dec 14, 2006 | 12:04 PM
SideStep's Avatar
I appreciate the post concerning oil use. It does seem to be a common point with forged motors that many are unwilling to speak about (for whatever reason...).
Old Dec 14, 2006 | 12:30 PM
ls1_doc's Avatar
I never realized that. Why does just forging a motor use more oil ?
Old Dec 14, 2006 | 12:41 PM
Sharpe's Avatar
Old Dec 14, 2006 | 12:59 PM
MrDude_1's Avatar
several variables come into play, but two of the large ones are: required clearance diffs between piston and bore, and aftermarket rings...
Old Dec 14, 2006 | 01:59 PM
Patrick G's Avatar
LS1 Tech Administrator
My Thunder Racing forged 346 uses no oil between changes. Some of this no doubt has to do with the LS6 valley pan conversion.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Dec 14, 2006 | 02:34 PM
chino_man279's Avatar
My APE 370 uses about 1/2 quart of oil between changes, ~4k to 5k miles. I am certain that all of this is being sucked in the intake as my FAST appears to be coated inside. I need to get a catchcan on this thing. Basically driving a forged motor as a daily driver is not a problem. Keep a quart of oil in the trunk, just in case, and drive.
Old Dec 14, 2006 | 02:48 PM
ONEBADWS6's Avatar
I'm sure most oil usage is being sucked throught the PCV system, it's very common. If you built motor is using alot of oil, slap the builder.
Old Dec 14, 2006 | 03:46 PM
JakeFusion's Avatar
Super Hulk Smash
Originally Posted by SideStep
What???
03-04 Mustang Cobra = Terminator.
Old Dec 14, 2006 | 03:47 PM
firefighter's Avatar
agreed onebad there is no reason other than the way it was built that a forged motor should use oil. slap that **** in da head.
note this statement/assumption is made with my experience from past SBC builds I really don't think that the motor being LS based should make a difference.
Old Dec 14, 2006 | 04:20 PM
Quickin's Avatar
-longevity?
-oil use?
An engine is an engine, forged doesn't make any difference. And I have about 60,000+ on mine and drive it now over 400 miles a week, yup, 400. Its perfect. Oil burn is high though but it has nothing to do with being a forged engine.
For the first 30,000 miles or so I used about half quart in 3,000 miles.
Old Dec 14, 2006 | 05:01 PM
JakeFusion's Avatar
Super Hulk Smash
The 4.125" crank have anything to do with that?
Old Dec 14, 2006 | 06:22 PM
Quickin's Avatar
Thats exactly it. short sleeve, long stroke.
Old Dec 14, 2006 | 07:26 PM
SideStep's Avatar
Thanks for the replies from everyone...
Old Dec 14, 2006 | 07:44 PM
BJM's Avatar
BJM
With modern forged pistons, do you have to set the piston/bore clearances to the point that you get a lot of start up noise, like piston slap?
