looking at building an ls7 with low end torque
Also if there are any threads on an engine like this, please point them out. I have been reading everything that has been posted for some time and have learned alot, but still to far away to go about building this on my own.
thanks all for any input
https://ls1tech.com/forums/generation-iv-internal-engine/571369-katech-value-427-dyno-test-3-cams.html
Check out the torque using the LS6 torquer cam in our Value 427. That was with LS6 heads and manifold.
bobd54321,
One suggestion that I have for you is to run the truck intake with larger injectors and the truck water pump. That way, you don't have issues with the fan design and the air intake. Westech has run tests that were reported in GM High Tech Performance that show the truck and the LS6 manifolds to be neck and neck through about 5,000 to 5,500 RPM's. The engine that Jason is describing would be a great combination for what you are defining as your goals. You might also want to consider a lower CR. For instance, at 9.5:1 versus 10.5:1, I doubt that you wold loose over 5 or 6% torque or HP and the operating costs would be significantly less for a daily driver.
Thanks all for the opinions, keep them coming
