L92 head gaskets
I plan on building a C6 Z51 6sp. L92/L76 combo. Current mods are long tube headers with high flow cats. 1 3/4; I know not the best for this set up but I don't want to buy headers again, x-pipe, corsa's, Halltech intake, electric water pump, low temp. thermostat, and ported throttle body. I can only get 91 fuel and elevation is about 2500'.Question what thickness head gasket would I need to get and do they make it, to get a compression ratio between 11.0-1 to 11.5-1 on stock LS2, or would I need to mill to get that compression. Also what are the trade offs when going to thinner gasket, what type of gasket materials are best when going thin.
Car will be daily driver and weekend spirited driving.
Thanks ahead of time!
http://www.torinocobra.com/Randys_tools.htm
From there you can shop for a target thickness.
Even if you are running a 4.00 bore, you still do not
want the head gasket hanging out past the chamber on the head.
These are what I will be using for my FI L92 build.
I would bet that most NA builds will require milling the heads
to get the compression up.
Many, myself included are trying to figure how much can be milled to get from the ~69cc chamber volume to the more desirable ~63-64 area. Having done that, the likely .050+ thickness of the GM gasket is an issue. Hopefully Cometic will deliver a .040-.045 thick 4.065" gasket.
Anyone one know the compressed thickness of the GM?
Hate to give up a higher CR and a good DCR.
I've got the short block/heads/intake just waiting.
I wonder if any of the sponsers could work up a deal for us?
Bob K.
Makes sense to me anyway.
See5, "I suspect the bigger chambers will change less per .001 of milling because it a smaller %. Makes sense to me anyway." I agree with you brother the larger the volume of a chamber the more it will throw the ratio of on the milling. I'm not an engine builder or engineer but makes sense, any vendors/builders want to chime in?
