408 cam
Old Dec 24, 2006 | 12:34 PM
gr8whte's Avatar
Default 408 cam
Would a g5x4 be good on a 408 with etp heads? or somthing else?
Old Dec 24, 2006 | 12:44 PM
Quik's Avatar
what are the specs of thta cam
Old Dec 24, 2006 | 12:46 PM
ls1408cp's Avatar
or just more info period
Old Dec 24, 2006 | 01:16 PM
gr8whte's Avatar
I do not no the specs lg does not say. The car is a 6speed its heads and cam right now,the stock bottom has some blow by. I had a Procharger on it with differant heads and cam and blew a head gasket I sold the Procharger and went with ETP heads and a Track cam from Thunder racing, now I think it may have broken rings, So now I am thinking of a ls2 408 and was going to change cams anybody have some suggestion on a cam? I thought about trying a G5X4.
Old Dec 24, 2006 | 09:07 PM
bigdsz's Avatar
I would NEVER buy a cam that I don't know the specs on!!! I mean if you don't know the specs how do you figure your DCR? I'm having a 408 built and I just got a Comp XER 244/248 .612/.615 112+2. This cam seems to be pretty popular on this site.
Old Dec 24, 2006 | 11:14 PM
baldurann's Avatar
Call Thunder and have them custom spec you a cam. G5x- series is designed for stock cubic inch motors.
Old Dec 24, 2006 | 11:29 PM
Quik's Avatar
yea thats the cam i have for my 408
Old Dec 25, 2006 | 12:12 AM
gr8whte's Avatar
Geoff at Thunder has always tuned both my cars and helped with my set ups he is awesome. thanks for the help, I going to stay with Thunder for cams, I have had 3 of them. Aluminum or iron 6.0 block? what is better
Old Dec 25, 2006 | 12:16 PM
Tom@SpeedInc's Avatar
Just make sure your running fair amount of compression, alot of these 408 cams have a very late closing, great for peak power, but a dog if you have under 11.5 SCR.
Old Dec 25, 2006 | 02:46 PM
gr8whte's Avatar
Thanks, I won't high compression for sure.
Old Dec 25, 2006 | 05:04 PM
slmdLS1's Avatar
I went with TSP's 257/266, .646/.622, and 113 lsa. (mines 11.3:1 CR)
Old Dec 26, 2006 | 11:53 AM
Cam02ss's Avatar
how do you like that cam and who built your 408? i'm in the process of doing a 408 so i'm just getting ideas
Old Dec 26, 2006 | 01:51 PM
bigdsz's Avatar
Not to hijack,but Fraser, on a 408 build my 5.3L heads are 63cc, am I better off with -8cc Wiseco at 11.4SCR or -10cc at 11.1SCR? I live in Florida and my friend nuked his engine, #7 piston, this past summer 11.7SCR. I'm paranoid these days. My DCR will be somewhere around 8.1
Old Dec 26, 2006 | 02:21 PM
LostCauseZ06's Avatar
thunder racing is who designed my cam, based it on another car they had in there and the cam worked amazling well on the low end and still shined on the top end like its built for.
Old Dec 26, 2006 | 06:49 PM
slmdLS1's Avatar
TSP built my 408. i cant tell you much about it(the cam), im still working on swapping parts over to get the motor in. i only get a couple hours a week to begin with and the holidays are killin my motor time. im also doing a fuel pump, and 9" as well.
Old Dec 26, 2006 | 08:48 PM
Myself? i'd go with Diamond -2cc pistons, MLS gaskets and 63cc heads, calculating mentally i'm finding 12.1 SCR.
Alot of people seam to damage #7 on nitrous, we havn't had issue with that IIRC.
Old Dec 31, 2006 | 05:25 PM
jeremym's Avatar
I have the same cam and I made 535rwhp NA w/26* of timing and my comp is around 12.5 comp. It is a 414ci iron block
