GTO LS2 Diesel
Bone stock except floor mats.
You never heard of piston slap on LSX Engin
Any one know if oil pump comes off GTO without droping pan?
Les
Piston - Piston to Bore Clearance - Production
-0.022-0.08 mm
-0.0009-0.0012 in
Piston - Piston to Bore Clearance - Service Limit with Skirt Coating Worn Off
0.024-0.08 mm
0.00094-0.0031 in
as far as the Timing Chain, If you have doubts replace it with a beefier one.
Les
When cold piston slap for a fiew mi.,realy bad when cold out. The chain was a surprise. I have installed with pan off never in car. The LS1 how to is down. I dont want to mess with pump unless it will come off.
Thanx
