yella terra
Old Dec 30, 2006 | 01:05 PM
Bandit28's Avatar
Default yella terra
has anyone had goodluck with these yella terra rockers? i am wondering if they are any good or if anyone is using them, I am also considering the harland sharp rockers, any info please help!
Old Dec 30, 2006 | 07:59 PM
phantom meneSS's Avatar
Yella Terra are a very well respected company "down under", they have been around for about 40 odd years and there product range and R&D is continually moving forward, I would not hesitate to recommend there products.
We use there products extensively without failure or complaint.
Matt Jackson
G&D Performance
Old Dec 30, 2006 | 08:06 PM
John B's Avatar
Moderator
PM me if you're interested in buying a nice used set of YT's!
Old Dec 31, 2006 | 05:55 AM
David Gordon's Avatar
I did back to back dyno runs with these and gained 0 HP. They did seem to quieten the valves a very little.
Old Dec 31, 2006 | 08:15 AM
Slowhawk's Avatar
LS1Tech Sponsor
We've used YT's on 4 engines about 3 years ago.They are still on with no problems.1 engine pushes 840rwhp.
Old Dec 31, 2006 | 08:59 AM
LSX Wizard's Avatar
Keep in mind that you wont usually "see" hp gains unless a) the previous rocker was deflecting/bending/distorting - not ususally the case unless you're running a solid roller with high spring rates *or* b) you are increasing rocker ratio, effectively adding usable duration and lift.
Old Dec 31, 2006 | 07:26 PM
Bandit28's Avatar
well well sounds good should i buy them for strength? more than hp
Old Jan 1, 2007 | 12:08 AM
racecar's Avatar
I have Comp Shaft Rockers with Valve cover spacers. Have about 1800 miles on them, 5 race weekends. No problems except the lock nuts came loose first time I fired the motor. I had to torque them to twice the factory spec to keep them tight.
Old Jan 1, 2007 | 10:26 PM
Bandit28's Avatar
so what is the true advantage over the stock rocker? Strength or looks or what?
Old Jan 5, 2007 | 07:30 AM
muscratmauler's Avatar
I have them on for about 12000 miles. I got them to quiet down the valvetrain and it did so very well. They are of good solid construction. Shaft mount as well.
Old Jan 5, 2007 | 11:43 AM
antz01ta's Avatar
10 Second Club + 14 Second Truck Club
i had a set of them that i ran for 2 years without issue and now they are on a friend of mine's 408 stroker with no issues. they are a very nice piece in my opinion.
Old Jan 6, 2007 | 12:05 PM
TNTramair's Avatar
Ive had these on since my first cam swap 3 years ago and they've been on ever since. no issues at all. very nice pieces...too bad im gonna have to get rid of them when i go to the l92 head (offset rocker design).
