What cam size
Dont know if the TR224 will get you to your goal of 400hp...but might get you close. Remember, the stock cam is like 209/214 (dont know exact specs).
Now, if you added,,,,say a Fast 90....then the TR224 would prolly get you there.
I should have a dyno in a couple weeks (currently getting it fine tuned)
cam: Comp Cams (custom grind) 226/226 591/591 112lsa, Patriot "gold" spring kit, comp cams chromoly one piece pushrods
Kooks Long tube headers (with catted connecting pipes
Borla Cat Back
and K&N FIPK
BTW.
I'm under the impression that the Fast 90 won't do much for us (with LS2's we already have a great intake and the 90mm tb) I could be wrong tho
Patriot Performance CNC heads with a port match FAST 90 , a sleeper cam ( watch your stall, you might need a small verter upgrade) on top of most the bolt-ons and i mean most. or get bigger heads and run a bigger cam, that would get you there easy
