L92 Valves
Old Jan 4, 2007 | 03:14 PM
Stang Killer's Avatar
Default L92 Valves
Been seriously considering buying a set of bare L92 heads to put on my 408 project, but I haven't seen a good set of valves, and i preferably don't want to use stock valves. Anybody know of a vendor or sponsor that has a really good set?...also...if i end up using a 4'' crank, what PVT am i going to have using...say a 630ish lift cam? Im a noob with this L92 stuff, and espically a noob on motors over 346ci so any help would be great.
Old Jan 4, 2007 | 03:23 PM
Stang's Bane's Avatar
The lift on the cam has no effect on the PTV, the duration does. The stroke has no effect on it either. Unless you already have the pistons for this build, I would strongly suggest having a set of pistons custom made for the L92 heads. Don't ask me how I know
Old Jan 4, 2007 | 06:45 PM
camarols1's Avatar
I called Manley, and they are supposed to be releasing new part numbers
for their stock size 2.16/1.59 stainless valves in a few weeks.
The part numbers will be 11620 and 11621.
I was told that the intake will be a "race flo" necked down stem, and the exhaust will be a "race master" straight stem.
I hope they get on the stick so I can get my project rollin!
Jobber price is said to be about $20 bucks each, seems like a deal!
Does anyone have an opinion on the durability of a stainless valve in a twin turbo (800+HP) setup?
Ferrea does makes a 1.60 exhaust valve designed for a turbo application, so I may use the Manley 2.16 intake and the Ferrea 1.60 on the exhaust just
to be safe.
Any thoughts on this?
Old Jan 4, 2007 | 08:09 PM
WizeAss's Avatar
most of the time cam lift and duration go together.... guys with lots of lift add lots of duration.
I am curious what a big lift small duration or big duration small lift setup would do on one of these!
Old Jan 4, 2007 | 09:09 PM
cendres's Avatar
Pretty sure I saw mentioned here that REV is doing these now...?
Old Jan 5, 2007 | 12:48 AM
dame's Avatar
Originally Posted by Forteen3GT
I am curious what a big lift small duration setup would do on one of these!
Id love to tell you "i'll let you know soon".............. but im sure .60x/.61x lift probably isn't considered big to most on here
Old Jan 5, 2007 | 01:14 PM
triumphman's Avatar
I have 16 Manley Intake valves [2.160] for sale if anyone needs them. $160.00 per 8
Old Jan 6, 2007 | 11:45 AM
Dragaholic's Avatar
9 Second Club NA
What's the pros and cons of stainless over regular steel? Will the aftermarket stainless be any lighter?
The Rev valves that are supposedly in the works, will they be stainless as well or will they be titanium?
Anyone make 2.16 titanium valves or possibly close to it and that could be turned down?
Old Jan 6, 2007 | 02:16 PM
jtl12419's Avatar
How do you know? What happened, so I don't make the same mistake too.
Old Jan 6, 2007 | 02:51 PM
WizeAss's Avatar
Ok... who has a stock valve to weigh... someone weigh one. Bret or Rick have yall done so?? What does an aftermarket 2.08 valve weigh for comparison??
Old Jan 6, 2007 | 05:10 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Someone knows they want to answer this.
Old Jan 6, 2007 | 05:34 PM
2c5s's Avatar
REV just made me a set of intake valves for my L92's, 2.160 ,pro flow style swirl polished S.S. 104 grams @ $156 for the set. They had them done in 1 day. Nice valves.....
Oh yeah, my L92/L76 408 is running in my V with these valves.
Old Jan 6, 2007 | 06:13 PM
Dragaholic's Avatar
9 Second Club NA
Is 104 grams considered light for that size of valve?
Old Jan 6, 2007 | 06:33 PM
I bought a set of pistons second hand, they were new but cut for a standard ls1. Now the valve reliefs in them will not match up with my heads. I am now limited on my cam choices because of this,
