L92 crate engine?
No idea if GM plans to offer the l92 through GMPP.
CATEGORY: All
PACK QTY: 1
CORE CHARGE: $300.00
GM LIST: $9,377.38
OUR PRICE: $5,615.20
May just be the longblock! Should be for the L92.
The 418 is from texas speed if I'm not mistaken and the 414 or 416 is at sdpc.
https://ls1tech.com/forums/showthrea...3&page=1&pp=20
quote is from the other thread.
GM L92 block 4.080" bore
Eagle 4.000" crank
Scat 6.125" "H" beam with ARP 2000 rod bolts (900HP)
Diamond -4cc Flat Top (Setup for L92 Cylinder Chamber, Includes HD Nickel Pins for BIG POWER!!)
Mahle Motorsports Plasma Moly Ring Set for 4.080" Finished Bore Size, File Fit 4.080" + .005"
Clevite H Main and Rod Bearings
Durabond Cam Bearings
L92/LS2 Conversion Peices (Timing Cover, Rear Cover, Timing Chain, Cam Sensor, Valley Cover, and Lifter Trays)
The motors are set up to run the L92 heads and L76 intakes. I have pricing on complete long block setups. The 90mm style throttle bodies available for LSX intakes will work on the L76 intakes. We have the injector harness adapters that will allow you to run the 40lb injectors from the L76 intakes on your LS1 vehicle as well as all the other conversion peices needed. I have complete Long Block Estimates that provide pricing for everything needed to drop on of these into your LS1/LS2 vehicle.
If anyone has any questions, needs an estimate or just wants some information you can send me a pm or give us a call!!
contact:
Mike Schropp
E-mail Address(es):
mschropp@livernoismotorsports.com
