Livernois Motorsports L92 Heads!
Old 01-11-2007, 09:24 PM
Moderator
JasonShort's Avatar
Originally Posted by MeentSS02
There's always someone out there that is gonna complain about the price...
Exactly right!
These heads look very promising
Old 01-11-2007, 09:29 PM
Chicago Crew UnderBoss's Avatar
Originally Posted by Sam88Gta1
Are you complaining about a assembled head that flows 360 and costs $1795???
You can add it up.
Heads $350
Valves Assume cost at $300
Spring set $350
That leaves port work at $795 including a 5 axis valve job.
Thats a damn good deal!!
Old 01-11-2007, 11:10 PM
bcs
bcs's Avatar
Anybody know if the heads will work well with a 408 with a 244/248 cam with 12cc pistons?
Old 01-11-2007, 11:55 PM
Bring the Noise's Avatar
Any plans on having GMHP test these on the LS2 that had the previous head comparison. Say with the same 232/236 cam just to see where they are over the stock L92 heads.
One last question: With all the R&D that you have put into the CNC design have you designed a cam to go with this head for the different displacements?
Say 2 cams for the 364 to 376 range (stage I and stage II) and then 2 cams for the 402 to 418 range?
Oh and an Idea to make it easier on buyers.
Offer them (the ported heads) in a package set where you can pick the cam, heads, and a set of harland sharp upgraded L92 rockers arms.
Old 01-12-2007, 12:40 AM
verbs's Avatar
=There's always someone out there that is gonna complain about the price...
and you send those people to Patriot Performance
Old 01-12-2007, 02:38 AM
Dale C's Avatar
Originally Posted by ss1
With all of the talk regarding valve float on a 2.200" steel valve (if used on the LS7), is this a concern with a 2.160" stainless valve on the L92 heads?
I also have the same concerns I am starting on a 418 for a road race application .650+ lift that will need to be able to turn 7500 RPM and hold it. Are there any titanium valves available for these heads? How heavy are the SS valves.
Thanks, Dale
Old 01-12-2007, 07:26 AM
Stang's Bane's Avatar
Thanks, Dale
Dale,
If you want to spend the money to have a set made and you have the time to wait, you can get anything you want. I don't think anyone has
shelf stock valves for this thing yet.
Keith
Old 01-12-2007, 08:40 AM
dame's Avatar
Intake runner size pease
Old 01-12-2007, 09:27 AM
LS1TECH Sponsor
Chad@LivernoisMotors's Avatar
Whoa guys...thats alot of questions I'll be in the office shortly and will answer all of your questions, thanks for the interest!!!
Chad @ Livernois Motorsports
Old 01-12-2007, 09:48 AM
Billiumss's Avatar
Lightbulb
You can add it up.
Heads $350
Spring set $350
$1795 is not bad at all for a good flowing head but these OEM heads cost next to nothing compared to what we had 2 years ago. The L92 flow better or equal to with no porting overall than most average LS1 STG 2 heads today.
Your a little off on the spring price, it's more like $150 for the singles they are selling, I have those springs on my car right now: http://www.motorsporttech.com/fbody_engine01.asp
So if we redo your math:
$150 for springs
$350 for both heads
$300 for valves
$100 GM seals, retain, locks
$900.00 ~ give/take $75-100
So that leaves $895 (give/take $75-100) for a port job
These are way cheaper than a AFR head but these are OEM pieces not aftermarket. I'm just surprised that they cost over $1,500 for a $175/each OEM head, thats all.
I hope they sell well, and will probably do so.
Old 01-12-2007, 09:51 AM
383ss's Avatar
can we please get a complete flow sheet, .100 to .700 both intake and exhaust?
also, what about upgraded spring packages and possibly a solid roller setup?
thanks!
Old 01-12-2007, 10:13 AM
  #32
deputydog's Avatar
Thanks, Dale
Dont forget the stock rockers wont be reliable with anything over 150lbs of seat pressure especially over 7000rpm. I considered the heads for a pretty stout motor that I'm building that is similar to Tosto's carbed motor. The good news is that Jesel is now shipping shaft rockers for the L92 head ( I just got off the phone with them) bad news is they cost...$1625
Old 01-12-2007, 11:13 AM
  #33
Definitely need pricing for a good double valve spring upgrade, good to at least .650 lift and I am very surprised that these heads would not automatically come with a PRC Gold or type dual spring good up to .650 lift.
Really interested to see how much power these will put out with a good matched cam in a 408 iron motor, 402 LS2, 416 L92, etc, etc. Its going to be a very exciting year 2007 for the LS series performance world!
Old 01-12-2007, 11:51 AM
  #34
Chalky's Avatar
Also curious to see some real world testing on smaller motor like LS1 vs 364 vs 402, etc. I just wonder if they will be to much for LS2 and smaller to be of any benefit.
Old 01-12-2007, 11:53 AM
  #35
9 Second Club NA
Dragaholic's Avatar
You need at least a 4.00" bore to use L92 heads. A LS1/LS6 block wouldn't work unless you sleeved it.
Old 01-12-2007, 12:14 PM
  #36
Chalky's Avatar
Good point on LS1/LS6. Still wonder if these heads are overkill on anything smaller than 400 CI.
Old 01-12-2007, 12:44 PM
  #37
LS1TECH Sponsor
Here are some numbers for now...working on answering everyones questions right now!!
Old 01-12-2007, 02:11 PM
  #38
pewter01z's Avatar
what about deck thickness. Comparable to LS1/LS6 or thicker like some of the aftermarket brands?
Old 01-12-2007, 02:15 PM
  #39
WizeAss's Avatar
Originally Posted by dame
Intake runner size please
this is a question few have answered.... heck I dont even know the factory specs on this.
also the exhaust numbers have me concerned..... I am starting to see why some are running huge *** splits in the cam selection
budget LS6 heads flow 300cfm intake and 213cfm exhaust at .600 lift...... considering where your cnc program is taking the exhaust flow......... I wonder if there is an issue with backpressuring the valves without serious exhaust work???
How do you compensate for this in cam design (just lift and duration, not looking for expert technical advise here, since I am still a newb)
Old 01-12-2007, 03:12 PM
  #40
LS1TECH Sponsor
Thanks for all the interest and questions guys! Let me post something that will clear some things up and hopefully answer all your questions.
Another update for everyone. We will offer FOUR stages on L92 heads. Stage 1, Stage 2, Stage 3, Stage 3R.
Stage 1 are assembled with Comp Springs, Manley Valves, GM Retainers. They are NOT CNC'd. These heads are offered at $1395.00
Stage 2 are assembled with Comp Springs, Manley Valves, GM Retainers, they are CNC ported with Valve job, milled, Seat blend, etc. These heads are the ones pictured on the website. They are offered at $1795.00
Stage 3 are assembled with Manley Dual Springs, Manley Valves, Manley Titanium Retainers. They are also CNC Ported, Valve job, Milled, Seat Blend, etc. These heads are offered at $1995.00!!
Stage 3R are to be determined yet but will use a larger valve. These are for you guy's with LOTS of cubes, lots of boost, etc.
These heads flow some great numbers and are assembled with GOOD parts. You can't beat the price guys! We do plan on making a specific head/cam package with these heads soon. The deck thickness is 1/2". As of now we dont offer the CNC job for customer supplied heads. I would answer all of your questions individually but we'll see how much this update clears up. If you have any questions, please post, or feel free to call. 313-561-5500
Thanks,
Quick Reply: Livernois Motorsports L92 Heads!
