View Poll Results: Max HP on a 427 all motor
500-600hp
27
17.53%
601-700hp
48
31.17%
701-800hp
26
16.88%
800+hp
53
34.42%
Voters: 154. You may not vote on this poll
427cid all motor can produce?
Originally Posted by MUSTANGEATER
I like saying TTT
Mods, the original poster obviously has no intention of making his question make any sense. I suggest the .
Originally Posted by SStrokerAce
Why is this thread always popping up to the top?
The solution is obvious and necessary:
Originally Posted by black_knight
Because people keep voting, despite the fact that it makes no sense.
Originally Posted by NemeSS
1.75 hp per ci would be nice, using ls7 type heads
I am doing ls2 402 stroker with full bolts on, 90Fast intake, 90tb, new MAF, lid, full exhaust, pulley, AFR225 heads, G5X3 cam = about 625 at crank or 510rwhp...with A4 built up tranny and 3000 stall, 3:73 gears...
625flywheel/402 = 1.55 flywheel hp per ci or very close to it. that's all motor NA setup with the very good bolts on heads and cam.
so to answer the original question, NA motor and supporting bolt on mods using some of the best heads and cam, full exhaust etc etc...full bolted on setup.
427 * 1.55 = 660-700 flywheel. give or take a few if A4 or M6.
