LQ9 engine question.
Old Jan 20, 2007 | 05:41 AM
vettefever17's Avatar
Default LQ9 engine question.
Do the blocks from SDPC include the main caps on the bare engine blocks? If not, isn't it a six bolt main? These may be dumb questions, but I'm used to the older GM blocks. Where can I get a good forged crank with a decent price. I've looked around jegs and summit, but have run into some problems. Isn't the LQ9 block a one seal unit or two?
Old Jan 20, 2007 | 12:55 PM
Steve Bryant's Avatar
LS1 Tech Veteran
Vettefever17,
All of the LS series GM blocks sold new come with the main bearing caps (this includes the LQ4/LQ9 6.0 L iron block). All of the LS series engines have single piece rear main seals and require a special installation tool or a lot of care so as to not get the seal lips flipped-over back wards.
Welcome to the world of new generation small block engines. I am 57 years old and have worked with cars and trucks (domestic and foreign) all my life. These are the best designed and manufactured small blocks ever. There is a learning curve, but there are some excellent books on the subject. I would recommend Will Handzel's book on these engines in particular!
All my best,
Steve
Old Jan 20, 2007 | 02:58 PM
Thank you for the reply. I'm planning to build a 408 to put into a C5. I'll have to look up that book that you mentioned, so I can get deeper into the ls series.
