L92 heads, forged pistons
Old Jan 27, 2007 | 01:11 AM
  #41
Bring the Noise's Avatar
Originally Posted by StingrayCrazy
Eric, I was planning on using the stock 6.0L 4.000" bore and the L92's since my block is new. Also since I'm going FI I could use the extra meat in the cylinder walls. Any trouble with the stock 6.0L bore clearing the valves?
Frank
With the stock valves you shouldn't. GM offers a 6.0 version of the L92 as the L76 (VortecMax in the 07 Silverado's).
Why not have a set of forged pistons made that match the stock L76 pistons that way you can get forged and low compression
Old Jan 28, 2007 | 07:25 PM
  #42
corvettetimmy's Avatar
I just got my setup running, and I am using the l92 heads with the ls1 style JE pistons #22180. I am running a cam with ~240 duration and almost .600 lift. So, I can say that the valves don't hit.............. so far!
Old Jan 28, 2007 | 07:29 PM
  #43
skipperbisket's Avatar
Jimmy, sounds like a nice setup, but with the cam you're running you shouldn't have issues. the cams some of the guys including myself posting in this thread will be using are considerably larger than what you're working with tho. any dyno results with your new combo?
Old Jan 28, 2007 | 07:38 PM
  #44
WizeAss's Avatar
are you having HKE build a L92 setup??? Just curious... I have not discussed what kind of driveability etc i am looking for in a cam.
Old Jan 28, 2007 | 08:05 PM
  #45
if i were do you really think i would share that kind of priveledged info with YOU?
Old Jan 28, 2007 | 09:20 PM
  #46
DoesSpeedTurnUon's Avatar
thats sounds just like mine! 244/250 - .596/.596 - 112
Same pistons and heads too in a 403
Old Jan 28, 2007 | 10:35 PM
  #47
motorbuilt's Avatar
Ok...so after all this talk about L92 heads NOT fitting with normal forged pistons, they will work with those sized cams and smaller??
Thats awesome if so.
Old Jan 29, 2007 | 12:33 AM
  #48
NoGamesLS1's Avatar
What type of power are you making?
Old Jan 29, 2007 | 01:37 AM
  #49
Cop Car's Avatar
if you used a cam that didnt need flycutting on an LS1, it would most likely work on the L92 heads on a 6.0 block with forged flatop pistions. i would double check however
Old Jan 29, 2007 | 01:47 AM
  #50
racer7088's Avatar
Arrow
Just running a random LS1 piston with L92 heads and valves and hoping it works isn't always the best plan. It might work and then again it might not work depending on lobe size and duration and any cylinder heads milling and then any valvetrain problems etc.
The exhaust valve in the L92 head is moved quite a bit and the intake is quite a bit larger and the ones I have had so far I had to cut as they would be hitting. The exhaust wasn't even close on one pair.
If you do not mill the heads though and are not using a huge cam they might even clear with a flat top. It all depends.
Old Jan 29, 2007 | 06:30 AM
  #51
TNTramair's Avatar
im have -15cc diamonds in my 402. the motor was built for FI and i was gonna use the l92s. im still lookin for a cam but will i be safe on running this combo if i stay with a cam around .600 or so lift?? thanx
Old Jan 29, 2007 | 08:48 AM
  #52
racer7088's Avatar
Thumbs up
I really don't know seeing so few of these yet. The stock intake valve is very thin on the margin so it may work but aftermarket valves and any milling of these heads and you may need the right reliefs. I will try and measure the free drop with a stock L92 valve.
Old Jan 29, 2007 | 12:17 PM
  #53
TNTramair's Avatar
the heads are off the shelf with stock valves and no milling. i appreciate any insight you can give me..but if not, its kool, ill just bolt them up when i get my gaskets and find out for myself and let everyone know...lol
