Spun Mains in 402
Old Feb 2, 2007 | 11:04 PM
pkincy's Avatar
Default Spun Mains in 402
Oh well thats racing.
My machinist is saying that it was likely detonation. Is he as full of it as I think he is?
My recollection is that spun mains are nearly always an oiling issue. Cracked ring lands is a detonation sign.
The pistons look good. Also I log continually as well as use a wide band often. I am saying BS to the detonation and most likely bad oiling.
BTW, he has some skin in the game on bad oiling since he rebuilt the motor 3000 miles ago due to a cam bearing that walked. I am guessing the motor had oiling issues he missed the first time around. This is the second rebuild in 7000 miles on a new 402.
Perry
Old Feb 2, 2007 | 11:18 PM
Mr.MartyStone's Avatar
Detonation? Ptbbhhhtt...that is most definitely an oiliing issue. I'm guessing your machinist just doesn't want to pay the bill. Plus I would find a new machinist.
Marty
Old Feb 3, 2007 | 12:29 AM
BLKWS6's Avatar
find a new builder...
Old Feb 3, 2007 | 01:33 AM
machinistone's Avatar
Never have seen detonation hurt a main bearing. Rod bearings yes, but not to the point of wiping one. You need to find a new builder...
Was the block align honed? Do you have clearance specs?
Pictures will be very helpful.
Old Feb 3, 2007 | 06:09 AM
antz01ta's Avatar
10 Second Club + 14 Second Truck Club
Perry
i had a front cam bearing walk out on me. what did he do to correct it? my machinist pinned the cam bearings in the bores.
i also agree that it sounds like an oiling problem.
Old Feb 3, 2007 | 07:40 AM
Bill's 02 Z-28 SS's Avatar
Hi Folks
I have never heard of that before - I would definitely look at oil pressure and bearing clearance. If they did not have the right clearance on the main and lack of oil, the bearing will spin.
Thanks
Bill
Old Feb 5, 2007 | 08:21 PM
helicoil's Avatar
Default spun mains
Trying to get to 50 posts. The LS engines oiling system is usually pretty good if assembled the right way with the right clearances
Old Feb 5, 2007 | 09:01 PM
jtl12419's Avatar
Just curious, what rods were you using?
Old Feb 5, 2007 | 09:05 PM
pkincy's Avatar
good question. SDPC is now using Scat H beam 6.125s in their 402s but mine was one of the first ones built and I recall it was Crower at that early date (12/04-1/05)
Perry
Old Feb 5, 2007 | 09:28 PM
Cop Car's Avatar
what the hell, ive never heard of ANYONE spinning a MAIN bearing. it wasnt put together correctly IMO. either something got in the motor, the crank was messed up, bearings were messed up etc.
Old Feb 5, 2007 | 09:46 PM
LASTLS1's Avatar
6 Second Club Moderator
I just had the same thing happen to me! The pistons, rods, spark plugs and all logs looked fine. They said it was detonation, I just don't understand how?
Old Feb 6, 2007 | 03:32 PM
Tiger2o69's Avatar
I have either spun as main or rod bearing as well. I have scat rods and stock crank. cleavite bearings.
Old Feb 6, 2007 | 04:04 PM
pkincy's Avatar
Perfect opportunity for new rods and a stroker crank!
Perry
Old Feb 6, 2007 | 04:29 PM
SUTTERERMAN85's Avatar
i would say that it is surely an oiling issue, i would also ask for oil clearances if he has them. that would be the first thing to do. next i would find a new engine builder. good luck to you.
Nick
Old Feb 6, 2007 | 04:32 PM
wheeelzzz's Avatar
Find a new engine builder
Old Feb 6, 2007 | 05:07 PM
NoGamesLS1's Avatar
who built the motor?
Old Feb 6, 2007 | 07:06 PM
Mercer Motorsports's Avatar
Never seen a main spun... please post up some pics.... seems to me that it would have to be an assembly and/or oiling issue.
I spun several rod bearings last year on a stock LS2 with less than 10 hours on it due to oil starvation... the mains were galled, but far from spun
Of course, it could have been my fault cause I was using the motor for this....
I'm a firm believer in the value of an oil accumulator now. At least for what I do.
Old Feb 6, 2007 | 08:12 PM
Brian Tooley Racing's Avatar
I would look to see if the plastic dumb bell that goes in the main oil gallery in the back of the block is there? If you put a welch plug in the back like is in the front then the oil will bypass the filter....kinda hard on mains....if you know what I mean.
Good luck Perry
Old Feb 7, 2007 | 01:01 AM
pkincy's Avatar
Good point Brian.
And I did check that when I had the cam bearing walk last year this time.
BTW, the heads show no damage. I am having the springs checked for pressure simply because it seems a reasonable thing to do with them off the car now. I am also having them look at the valve seats but am expecting everything to be OK. I don't think I have but 10-12,000 mostly street miles on the heads.
Keep up your good work.
Perry
Old Feb 7, 2007 | 02:31 PM
lilbuddy1587's Avatar
Good point Brian.
Perry
Take your **** to AZPS
