Advice na monster
As for 8000+ rpm's.... oiling would definately be a concern, but the valvetrain stability would be a bigger one I think. A dry sump setup would solve the oiling issues, pro probably make more power, especially if a vacum pump or anything like that is part of the plan.
Talk to some of the guys that build the big n/a power setups, futral has done a few big ones, w2w has as well (camkhawk's motor I think)
I'd talk to the guys that have experience doing it, they will be able to tell you the most
I wish, but NMCA/PRO is where its at if you want to compete and make money they have races in Chicago, Memphis, Bowling Green, and Ohio.
It'll take a serious effort to compete but when you're going 8's N/A with a Small Block you'd fit right into this class.
You are running a pretty big hyd. cam now, how much it would pick up going to solid roller would depend on the compression you go to, and cam size. You're probably running about as big as you can with hydraulic stuff.. what have you got on that for springs/rockers now?
the problem is that the best ETP heads flow about 420 cfm I believe, and a solid roller, 8K rpm motor swinging a 4.5 in. crank is a hard thing to make live a long time!
