.700+ solid W/factory ls7 heads
Just be sure to plan everything in the right steps. may want to machine the pockets first before you select valve length. You may end up machining a lip for a 1.550 valve spring only partially down in the pocket...then add a shim of a smaller diameter into the original pocket..then place an ID locator over the top of those. At that point youll need quite a long valve.
But I think the LS7 stuff with its HUGE valves is ripe for a solid high lift cam. Cam lift is predicated on valve size.
in my hunt for 700+ lift i founf that your going to need to go to a 1.600 spring minimum to get it, highest lift i found for a 1.550 spring was the manley next tek tool steel spring and they go to .700 lift with a 1.850/1.800 install height don't remember exactly.
PSI makes some springs that may with 1.50
and defiantely shaft mount and almost certainly shimmed for correct geometry.
