What head gaskets to use on a LS2 with L92 heads
You shouldn't be worrying about your SCR, you should be worrying about your DCR. 10.9:1 or whatever SCR means nothing if you don't know your DCR. I personally wouldn't go with the stock .060 gasket, that's way too thick. Figured out how far out of the hole your pistons are and add .032-.035 to that to see what thickness you want your gaskets (unless that creates too high of a DCR, then you can add a bit of thickness as a temp fix, but that's a diff issue).
Sorry, typed 10.9 instead of 11.9:1, my bad. And as stated, DCR is something to consider as well. Post up your cam specs and some of these wizards can help out more with that!
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
