Cam Experts
Old Feb 20, 2007 | 04:34 PM
Vr6aaron's Avatar
Default Cam Experts
Hey guys rookie here what can u tell me about these cam specs
227.227 .629/.629 lsa 116.
what could i expect. I have AE headers with Vararam intake. Pleae let me know.
Old Feb 20, 2007 | 05:07 PM
Patrick G's Avatar
LS1 Tech Administrator
Is this on a C6 with an LS2? Automatic or 6 speed? Tell us more about your mods and your goals.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Feb 20, 2007 | 05:15 PM
Vr6aaron's Avatar
Yes C6 six speed. I want a stealth silent killer. LOl. I have 1 3/4 Ae headers and Vararam intak with corsa's. thats it. Plan to install ARF heads as well 205 non milled.
Old Feb 20, 2007 | 07:34 PM
Vr6aaron's Avatar
No one?
Old Feb 20, 2007 | 08:16 PM
DONAIMIAN's Avatar
Why not go with one of the quiet cams thats already out like a stealth, cheater, or old man cam?
Old Feb 20, 2007 | 08:22 PM
Patrick G's Avatar
Since you have headers already, you can go a little larger on the intake lobe and a little smaller on the exhaust (compared to the CheaTR cam).
For pure stealth, you may not want the high intensity XE-R or LSK lobes. They are very loud, but they will make a ton of power. If you want performance-stealth, then the faster-ramped cams will make more power with less overlap (lope).
The AFR 224/228 .581/.588 114LSA +1 cam uses Comp XE-R lobes and has proven itself to be a very capable performer with the mods you have. In an LS2, it would be very stealthy (outside of the sewing machine sound from the valves, LOL).
__________________
Old Feb 20, 2007 | 08:56 PM
03 BUSA's Avatar
V6aaron, Listen to Patrick G He is the man when it comes to this stuff. I would take his knowledge and run with it without a second thought. Trust me, he has already saved my ***.
Old Feb 21, 2007 | 12:12 PM
Vr6aaron's Avatar
So where can i get this cam? AFR directly?
Old Feb 21, 2007 | 12:19 PM
gnx7's Avatar
You should mill the heads at least to 62cc (with .040 Cometic head gasket results in about 11:1 compression) for as much compression as possible for the octane you plan to run. Giving up free torque/HP if you don't and leave the chambers at 66cc. Potentially 10-20 ft/lbs tq.
Then if you need to mill then additionally to 60/58cc down the line to clean up the mating surface (if you blow a head gasket or rebuild the engine) and get even a bit more compression.
Listen to PatrickG... he knows cams. You should search under his name for what cams he tried out and their delivered power range.
