View Poll Results: How much will it make?? Cam of YOUR dreams!!
650-675 CRANK hp
45.45%
675-700 CRANK hp
27.27%
700-725 CRANk hp
27.27%
Voters: 22. You may not vote on this poll
My build thread
Old Feb 23, 2007 | 09:30 AM
Stang's Bane's Avatar
Default My build thread
To start things off, the cam will be a custom grind by B.R.E., the question is what do you think it is capable of making with the perfect cam in your mind. I am going with what Bret spec's out regardless I just was wondering what the opinion of the ultimate potential of the factory ls7 port is. Heads will have port work on the exhaust side, aftermarket TI valves,& valve job. I am looking at between 11.75 and 12.2 SCR. I am doing this no holds barred other than hydraulic roller and I will occasionally have to drive it on the street. I am letting Bret have free reign to do what he feels he needs to reach what my goals are.
As the title says here is my build thread. I have listed items I already possess and items that I NEED. I know that I could REALLY use a rearend, but I am just talking about just to get the engine in the car and running. The car will be completely gone through and be be built bulletproof. Completely new suspension, built tranny, the works. I just am trying to get it running for the Car-Craft Summer Nationals in St. Paul, MN. on July 20-22. Motor will be broken in and tuned on an engine dyno, will have graphs available when that happens. If you see anything I missed on the need column let me know!!
PARTS I ALREADY HAVE
1. Shortblock
a. callies dragonslayer carank
b. callies compstar rods
c. diamond -7cc pistons
d. all bearings
e. drysleeved block
2. intake manifold
3. cylinder head bare cnc castings (LS7)
4. billet steel flywheel
5. LC1 wideband
6. new slave and master cylinder
7. front, rear, and valley covers
8. accessories off of my engine
9. 1 7/8 Kooks headers
10. K member
11. Valve covers
12 Timing chain
13. Lifters
14 Clutch (TEX OZ700)
15. Torque arm (Spohn tunnel mount!!)
16 Oil Pump
17 All new sensors for the block
18 Head studs
19 Rocker arms(factory; HS mod done!!.)
20 All new bolts for covers, and intake manifold
21 Fuel pump
22 Fuel rails(custom aftermarket LS7)
23 injectors (Mototron 60#)
PARTS I STILL NEED
8. plugs
9. wires
12. driveshaft
14. wheels and rear tires (17x9 front, rear either 17x11 or 18x10.5 or 10)
17. header back exhaust (either duals with a x-pipe or 4” y and 3”cat-back with cutout)
Old Feb 23, 2007 | 03:58 PM
superchargedbandit's Avatar
What Power Are You Hopeing For?
Old Feb 23, 2007 | 05:16 PM
700 + crank
Old Feb 23, 2007 | 05:49 PM
11 Bravo's Avatar
Originally Posted by Stang's Bane
700 + crank
Don't get too hung up on that number lol. You need to add a fuel pump to your list.
Old Feb 23, 2007 | 06:10 PM
Not too hung up, just something to shoot for Added fuel pump
Old Feb 23, 2007 | 06:24 PM
11 Bravo's Avatar
If you are building it from scratch, all the bolts you need are a PIA. The intake, covers, cam retainer, oil pump, ect. If you're buying all that stuff seperate, they don't come with the bolts depending on where/who you get them from.
Old Feb 25, 2007 | 05:32 AM
bump...
Old Feb 25, 2007 | 11:37 AM
dame's Avatar
is this going to be another top secret cam spec build?
(honest question.... not trying to flame at all) good luck on the build...... might I suggest the twin intanks from lonnies performance (racetronix doesnt sell them directly anymore)
Old Feb 25, 2007 | 01:25 PM
Yes the cam specs will be secret. I respect Bret for wanting to keep the specs secret, as this is how he earns his living. As of now, I have no idea what they will be. Nor do I care, as long as I make a 10 sec pass with it
Old Mar 1, 2007 | 04:05 PM
vanilla89's Avatar
i love my B.R.E cam,it pulls just as hard at 3000,as it does at 6000,and pulls to 6800
Old Mar 1, 2007 | 06:29 PM
WKMCD's Avatar
You bastard!!!
Old Mar 1, 2007 | 10:16 PM
Spinmonster's Avatar
You can make a 10 sec pass with a stock bottom end but this is a killer project....good luck with the build.
Old Mar 8, 2007 | 09:33 AM
Updated list. I am now the proud owner of a nib set of 1 7/8 Kooks headers
Old Mar 10, 2007 | 04:02 PM
WKMCD's Avatar
It's just money.
I sold my 1 3/4 and went with American Racing 1 7/8 for the 402.
Old Mar 10, 2007 | 08:22 PM
FRDnemesis's Avatar
A few questions:
Who is Brett/whats his specialty?
What are the cubes?
I'm assuming 416 or bigger, so why straight 1 7/8" (and not stepped to 2")?
Jeff
Old Mar 10, 2007 | 08:47 PM
See sig for cubes.
Brett Bauer of Bauer Racing Engines. Specialty is making horsepower
As far as the headers, Brett said that the straight 1 7/8 would be enough.
Old Mar 10, 2007 | 10:02 PM
Originally Posted by WKMCD
It's just money.
I am just trying to get Bret to take a check! If everyone will, hell, I'll pay it off.
Old Mar 22, 2007 | 08:35 AM
Updated needed items. "Moving on up to the sky!!" Jefferson's FTMFW
Old Mar 22, 2007 | 10:02 AM
WKMCD's Avatar
Any dyno numbers yet..
Old Mar 22, 2007 | 10:14 AM
6,125,985 LOL
shortblock=Houston
Heads=NY
misc ****= all over the damn country!!
I am hoping to be complete, motor boke in and with dyno numbers by the last week in June.
