so whos making the most power on an ls2 block?
I have posted a few times about doing the first lsx supra swap. I know I'm going to have to make some stupid HP levels to shut up the supra guys seeing as now 1000rwhp is hardly impressive on the 2jzgte's.
I remember year or two ago Y2khawk (I believe) posted about going for 1500rwhp or bust. I’m pretty sure that the lingenfelter 427 LS2's make over 1000 to the wheels. So I know 4 digits is doable.
Who is making the highest power levels on an ls2 block?
FYI I’m thinking twin T72's and 400+cubes would help me get their
thanks in advance guys
But whatever you do I suggest just trying to make a nice broad powerband of 800 rwhp and shut all of them up when you actually run the number and not an 11.XX's@145.
Marty
Remember for the cast in grey metal liners inside a LS2 will not handle a large amount of boost.
Now if you switch up to wet or dry sleeve forged liners (MTI, etc) you can apply alot of boost. Or you can go with the cast iron 6.0L block.
Considering how much power you are planning to produce I would expect you are planning on alot of boost between the 2 turbo's to exceed 1000rwhp.
You would be safer off with either a warhawk or lsx block. The 6 bolts per cylinder to mount the heads plus better cylinder liners would be better suited for the large amount of boost you plan on using.
Just my 2 cents
