Anyone run the camotion cam
He had 4 degrees added into his cam. What are your pistons relieve numbers. Also what gaskets did you use. He has copper gasket stock thickness and -2cc reliefs...
by the way i also made 550rwhp 501 rwtq, with this cam with untouched AFR225's and untouched Fast 90
I don't know what to tell you. It does not like anything that low, we tried it. The car will run but doesn't sound good at all. I was hoping to have a 900 or so idle. Maybe with some more tuining it will be better. Those numbers are very impressive. If I can come away with a little more torque than your setup I will be very happy.
