427 Cam Experts, need perfect cam for max effort street/strip 427!
#41
Originally Posted by PowerShift408
Underboss, I think you should click that link at the bottom of Patrick G's signature that says custom camshaft help. He will recommend you a couple of different cams and give you a breakdown on why they will be good for your setup along with valve events, SCR, DCR, etc. I recently did it, don't have results yet, but I'm very confident in Patrick. They guy knows his stuff.
GUYS,
Thanks for your advice but just for clarification this is a very old thread I started 4 months ago, and I am no longer looking for this cam shaft info although I am sure several others are.
![Lurk](https://ls1tech.com/forums/images/smilies3/lurk.gif)
Anyways, this is just a real old thread that BRIAN AT TEA Resurrected for the heck of it, b/c at the time I was going to build a 430 cid LME motor with Brian's/TEA 235 Trickflow heads. That project is on hold for time being pending the results of some newer engine builds with the LSX motor, etc.!
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#43
Wow, didn't see that... My fault!
No problem bro, still makes for some good reading and some new info being added here and there!
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
