First Peek at LSx Brought To You By SDPC!
does it look like an alum rod will work?
maybe some grinding needed, but wont be in the way of oil?
thanks.
looking good.
"My Buddy" cant wait to get his!!!
Matt
Will the Warhawk heads fit on it?
Jay Johnson
I was under the impression it came with a custom set of lifter retainers ... i.e. we wouldn't have to swap to tie bar lifters. Oh well... more money
Kurt
i was also under the impression thatthey camewith a"lifter tray"
as for alum rods, i wasnt sure if they hit the bottom of the cylender or what. haventsen this block in person yet?
The guy at PRI said that any LS based head will bolt on, but if you want to use the extra head bolts, you'll have to get with one of the aftermarket head guys like ET or A/P, maybe World will offer the GM bolt pattern in their heads down the road too.
The same guy had a small nifty 2-lifter retainer thingy that bolts down and works like the factory lifter tray. I'll bet that Jesel will eventually make a dogbone retainer that bolts in that same hole for high-end lifters.
Now i would have known that if ours were here
Are they all ""SOLD""
They come with Billit Main caps correct??
Main Studs from ARP ready yet??? Anyone know the prices on them???
Kyle
Kyle
They come with billet main caps. I believe standard LS1 main studs would work.
What about the Head Studs?? ARP Making them yet??
You guys match the Price SDPC has??
Anyone have one together and running yet ?
I know the current aftermarket heads don't have the extra bolt holes,
but can you drill em out and make the holes?
You can run without using the extra bolt holes right?
Do all the other LS1 parts bolt up easily ?
but i know they just shipped andpeople will have them going together real soon.
like as soon as Dimond can get me some pistions
