Ordered my TEA/TFS 225cc heads!!!!!
Old Apr 28, 2007 | 02:38 PM
jeremym's Avatar
Default Ordered my TEA/TFS 225cc heads!!!!!
I ordered my heads last week. I went with a 68cc head w/ Harland Sharps RR and a .045 gasket. That puts me at 11.8 comp. with -2cc flat top piston that comes 4 out of the hole. My cam is a 244/248..612/615..112LSA and I have all the other goodies like KOOK 1 7/8 LT 3inch true duels w/ X pipe, and FAST 90/90. Couple of ?'s . Will the Harland's fit under stock valve covers and if not how to get them to work? Will my Comp. and DCR be good for a N/A street car? What does everybody think I will make at the rwhp thru a 6spd?
Old Apr 29, 2007 | 05:37 PM
jeremym's Avatar
Can anybody tell me if my DCR will be good on this set up?
Old Apr 29, 2007 | 06:19 PM
Wnts2Go10O's Avatar
itll be fine with good tune. tht thing is gonna be nuts. im not to sure about the rockers though, its easy to check so dont worry so much bout that. id get that 90/90 ported if you hvent. im sure theres power to be found there.
Old Apr 29, 2007 | 07:21 PM
jeremym's Avatar
No the 90/intake is not ported. I hope its going to be nuts. These heads should make killer peak #'s, but should make killer #'s through the whole curve. The mid flow #'s are good on the heads. Will will see soon.
Old Apr 29, 2007 | 07:50 PM
osuqsz06's Avatar
your setup is very close to mine that im going to be installin w/ the next 2 weeks. im pretty sure the harlands fit. as i planned on runnin the stock valve covers. as far as power im shootin for 560rwhp+ but with a bigger cam and ported fast. honestly id say 540+ through a 12 bolt
Old Apr 29, 2007 | 08:03 PM
jeremym's Avatar
The sad thing is I still have a 10 bolt. The 12 bolt is next on the list. I hoping for 550rwhp range. May I ask what spec or round about size cam did you go with?
Old Apr 29, 2007 | 08:09 PM
osuqsz06's Avatar
pm sent!! as far as through the 10 bolt id say you should hit 550 or close to it anyways.
Old Apr 29, 2007 | 09:25 PM
jeremym's Avatar
After the 12 bolt I will take it to the track, but for now roll racing is for me.60 punch
Old May 2, 2007 | 09:05 PM
Brian Tooley Racing's Avatar
Your heads are about ready to go, and we got the new TFS 235's on the flow bench today, they are REAL good for a little 2.08 valve on a 4.125 bore, numbers are coming. I may try to flow them on a 4.060 bore tomorrow.
Old May 2, 2007 | 10:31 PM
getusum's Avatar
Your #'s should be close to what you are aiming at...I have the same heads, 90/90(ported) jesel 1.8's similar cam 244/250...630/630....531rwhp/517rwtq on a dynojet through a 9inch....did 502/470 on a mustang 1750 on a 10 bolt....N/A....
Old May 3, 2007 | 07:13 AM
Stang's Bane's Avatar
Did you ever get numbers????
Old May 3, 2007 | 07:29 PM
383ss's Avatar
awesome, can't wait to see some more info on the 235's.
Old May 3, 2007 | 10:10 PM
jeremym's Avatar
Thanks man. What spark plugs should I get with my set up? Which heads are you flowing tomorrow? Cant wait till I see what they do.
Old May 4, 2007 | 12:01 AM
transAm-98's Avatar
Very curious to see how they will flow on a 4.060. I'll need to order some heads in the next month or 2, and would love to go 235's if they will still keep the velocity up.
Old May 4, 2007 | 04:47 PM
jeremym's Avatar
Brian, do you have any flow num#'s yet? Are you going to flow my heads on a 4.060 bore? If so pm the flow num#'s. Thanks for all your and Mikes help these past 4wks.
Old May 9, 2007 | 11:05 AM
transAm-98's Avatar
TTT any numbers on the 235's on a 4.060 bore yet
Old May 9, 2007 | 01:18 PM
jeremym's Avatar
Look at TEA 's web.
Old May 10, 2007 | 01:13 AM
transAm-98's Avatar
Looks like I might have to go with the 235's
