Gasket Question
Old Apr 30, 2007 | 07:37 AM
ZLEEPER's Avatar
Default Gasket Question
Anyone know which gaskets to use for a LS2 402 with L92 heads?? I tried 6.0L truck gaskets and it appears we're getting some combustion blowby. It's steaming out of the VC breather.
Are the L76 or L92 6.2L gaskets the way to go????????
I tried a search and didn't find anything definitive.
Chris
Old Apr 30, 2007 | 07:55 AM
RGKSR's Avatar
Default FelPro 1161 or 1041
I'm installing FelPro 1161's (.053 thick) on mine. The local shop swears by them. He also said the Fep Pro 1041's (.041 thick) would be ok.
I'll know after the Caddy lifter arrive at SDPc and the turn them around!
Bob K.
Old Apr 30, 2007 | 08:26 AM
ZLEEPER's Avatar
What diameter bore are these for?? 6.0L or 6.2L ???
Old May 1, 2007 | 08:24 PM
RGKSR's Avatar
Default Fel Pro 1161L
The spec's are 3.946'' to 4.100'' bores.
Bob K.
Old May 1, 2007 | 10:48 PM
TrekGTO's Avatar
I used stock 6.2L
Old May 2, 2007 | 06:12 AM
See5's Avatar
The gasket should be 4.065 or more 6.2L. The 6.0l gaskets will interfere with intake valve, I think.
Old May 2, 2007 | 10:34 AM
RGKSR's Avatar
Default 1161 L&R's
FelPro 1161's are 4.100".
Bob K.
Old May 2, 2007 | 05:08 PM
ZLEEPER's Avatar
Well, I hope switching to the 6.2L headgaskets will solve my problem.
Thanks guys
Old May 2, 2007 | 06:34 PM
NemeSS's Avatar
iirc the 6.2 gaskets are 4.090-4.110 bore and .055 thick
which come at about a 11.84-11.96 cc
Old May 2, 2007 | 10:53 PM
TheBlurLS1's Avatar
That's what she said...
Are you sure that "steam" out of the breather isn't oil mist/residue? 99% of people's breathers smoke.
Old May 3, 2007 | 01:27 PM
ZLEEPER's Avatar
That's what I assumed as well, but Mike and the guys tuning agreed that it was a little excessive for the "normal" steaming...
