~ 8k rpm solid roller sheet metal ls7 style
Old May 3, 2007 | 10:00 PM
Greg Fell's Avatar
Default ~ 8k rpm solid roller sheet metal ls7 style
Thinking of doing a big bore, short stroke, solid roller sheet metal, LS7 style (maybe L92s even?) freak show.
Has anyone done one, or know of anyone who has? Any results?
Thinking of these options that may vary
4.155-4.200 bore
3.622 stroke (stock crank)
All-Pro LSW or ET LS7 Solid Roller (anyone have any luck with L92 solid roller setup?)
Beck Sheet Metal Intake
American Racing 1 7/8 Headers
Winging it to 7500-stock pcm limit (8k?)
Old May 4, 2007 | 01:59 AM
Ryne @ CMS's Avatar
LS1TECH Sponsor
what about the warhawk ls7x heads
Old May 4, 2007 | 07:28 PM
gun5l1ng3r's Avatar
I think Katech already builds a 5.7 L with LS7 style heads and it Revs to ~8500RPM...
Old May 4, 2007 | 10:18 PM
Greg Fell's Avatar
any more info on it?
Old May 4, 2007 | 10:27 PM
Retail Value's Avatar
http://katechengines.com/street_perf...e_packages.php
Sneak Attack LS7 package.
Old May 4, 2007 | 10:54 PM
Greg Fell's Avatar
ah yes. put me down for 2. $30k?
Old May 6, 2007 | 02:06 PM
04gtoBMXracer's Avatar
how about something more affordable?
Old May 6, 2007 | 05:00 PM
Greg Fell's Avatar
yes indeed.
it doesn't seem like anybody really has any results from this type of setup, i'd love to hear if you have.
Old May 7, 2007 | 08:56 AM
Steve Burger's Avatar
LS1TECH Sponsor
I was told for something like this I would need a liquid cooled wallet. I did ask one sponsor about an LSX block package that was in the range listed. It was 24K without frills.
Old May 7, 2007 | 09:10 AM
Greg Fell's Avatar
i'm coming up with about 13k for parts, and a wet sump. not sure if that would work....
Old May 7, 2007 | 10:43 AM
Stang's Bane's Avatar
Ask LS1 Joe what hew has in his ~400 cube motor. It is wet sump and he spins it to 8800 EVERY pass..
Old May 7, 2007 | 12:26 PM
Greg Fell's Avatar
i am having problems with his screen name...any more info you can give me?
Old May 7, 2007 | 12:33 PM
evojuiced's Avatar
biggest thing is going to be oil volume, a Accusump will keep the motor oiled when you empty the pan, and you will empty the pan on a 8000+ rpm motor.
I would listen to Richard about his LSW heads, if i had a 4.125 bore i would run them, in person they look like a work of art!
Old May 7, 2007 | 12:55 PM
I think the screen name is six speed inc. or something. He is the guy that owns t56 rebuilds.
Old May 11, 2007 | 12:52 PM
BlackLS7's Avatar
Saw this at PRI in orlando last December
Old May 11, 2007 | 02:03 PM
Yeah, as far as looks that thing is pure sex. But I really haven't seen that it is worth the extra money over the LS7 intake. 20 hp=$2500= not for me. If I was doing an all out competition engine, then maybe. But for a street motor, the factory LS7 is plenty.
Old May 12, 2007 | 08:40 PM
ls1 joe's Avatar
I have had good luck with my Melling oil pump and Moroso oil pan windage tray and pickup. I am switching to dry sump on my new build because I am going to turn the next beast to 9000rpms. The 402 liked to be turned lots of rpms. I have had very good luck with my Beck manifold, but I do know that Patterson racing uses a lot of the Wilson stuff. I would like to see a A to B comparo between a Wilson manifold and a Beck manifold.
