what the hell is going on with Comp 918s????
Old Jun 15, 2007 | 11:31 AM
  #121
95ttoplt1's Avatar
http://www.lxforums.com/board/showth...t=68960&page=2
Apparently we have an expert in here, he was going to post on here as well, but he is yet to be seen.
He thinks the cams were too big for the springs, but I think someone has broken them with a stock cam correct??
Old Jun 15, 2007 | 01:06 PM
  #122
Mike454SS's Avatar
Originally Posted by pwrtrip75
on the corvette forum ones.....i'd lean towards something else was wrong. Did the springs ever get baked? who put the springs on and the rest of the engine together?
10 broken springs I think is the result of something other than the springs being 100% at fault. what was the lift? shims? stock rockers? pushrods? heads milled? anything altered from stock? Theres got to be something else.
Springs binding from too much lift...be it from the cam being too big for them or from nobody checking installed height? I know a LOT of people running 918's without problems at all...but then again most of them asked me to install them, and I check the installed height when I do it, and I also make them run an oil temp gauge and I usually explain to them to think of it more as a gas pedal gauge...don't hit the gas pedal until the needle is over here .
I will agree it seems awfully strange to see it happening to so many people in the same spot on the spring every time...but there are a LOT more out there that aren't seeing this problem at all...nobody posts a new thread every 10K miles just to say "hey, my valve springs are still not broken".
Old Jun 15, 2007 | 01:45 PM
  #123
wrd1972's Avatar
Originally Posted by TKAYRC3
My 918 Spring brokeon my 02 T/A, yesterday, I dropped a valve, broke a rod & cracked an LS6 block & destroyed one cylinder head, Do you think comp is gonna pay for that!! I had a TR 224 cam with stock heads!! I'm screwed!!
Man that is just terrible. I feel for you guys who have lost motors over this. I would try to get Comp to cover the costs but I am sure they wont even consider it.
I caught my busted 918's before any valves dropped.
Old Jun 15, 2007 | 02:38 PM
  #124
916LS1's Avatar
Could this be why we don't hear as many broken spring stories as we should? My car ran fine with the broken springs for probably a couple thousand miles, of course, I have no idea when they broke, I just know for a fact that my car ran well with broken springs. I only pulled the valve covers after learning I had one of the bad batches. I bet many people THINK their springs are fine, when in fact they are broken; maybe on the verge of dropping a valve.
Old Jun 15, 2007 | 04:39 PM
  #125
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
My rep at Comp just called and someone there wants to speak with someone with a broken spring....not in e-mail, not hearse on the net...they want to talk with someone. If you've actually got a broken spring, please call me so I can get your contact info and I'll have Comp call you directly.
Sorry I don't know more of what they want to talk about...he just asked me to get them in contact directly with someone. I'm here until 6:30pm central...800-456-0211 and just ask for Matt.
Thanks!
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Jun 15, 2007 | 04:56 PM
  #126
Thanks Dr. Jeckyl!
__________________
Old Jun 15, 2007 | 05:13 PM
  #127
Dr. Jeckel's Avatar
No problem
Old Jun 16, 2007 | 10:55 AM
  #128
eddiepoindexter's Avatar
Originally Posted by speed_demon24
Or maybe its has to do with the fact that comp switched spring suppliers.
speed_demon24 got it right and nobody listened. Peterson American Corporation (PAC) was making the 918's and now Comp is sourcing them from another company. It's NOT an installation issue!
Old Jun 18, 2007 | 09:58 AM
  #129
Yeahdoug's Avatar
It has everything to do with Comp switching suppliers. The batch numbers I have seen comfirm this.
Comp switched manufacturers from Peterson Spring (PAC Racing) in early 2006 to one of our competitors. We made the original 918.
You can get the original 918 still through us. The new part number is PAC-1218.
We also ahve a bunch of other really cool LS1 stuff. Like the next evolution of the 918. The PAC-1518.
Feel free to ask me any questions. I run PACs valvetrain dynamics lab.
Please spread the word as we can't hit all the websites to warn people.
If the batch number is 29XXX and lower you have the older 918s from us. Anything else and you have the newer ones that appear to be failing.
Old Jun 18, 2007 | 11:29 AM
  #130
Yeahdoug's Avatar
Oh and I am trying to do this without soliciting as much as possible but it's hard not too. I think that this problem is large/important enough that this infomation is valid. I took out any contact info.
Old Jun 18, 2007 | 12:42 PM
  #131
Smile Call Crane!!!
The PAC-1218 is also available from Crane Cams Inc. under Crane part number 99831-16.
Old Jun 18, 2007 | 01:13 PM
  #132
Yeahdoug's Avatar
Yes it is.
Old Jun 18, 2007 | 01:46 PM
  #133
wrd1972's Avatar
What is the big diffrence between the 1218 and the 1518 springs. I have the 1218 springs and I was wondering at what point they should be replaced regarding certain amounts of lift.
Old Jun 18, 2007 | 02:03 PM
  #134
DeepBlueZ's Avatar
interesting.....
  #135
Yeahdoug's Avatar
We recommend our PAC-1518 for anything above .600" to .650" lift because of the higher stress range. It's also a better spring for engines that will be turning higher RPMs or using a camshaft with aggressive ramps. The nitriding and other added processes we do give the springs even better fatigue life then the 1218 and can handle more punishment. I have ran the 1518 from free length to solid on our testers and haven't been able to break one after double our normal test length.
The 1518 is the next evolution of the 1218 (918). It gets a lot of the same processing that our cup springs do
Old Jun 18, 2007 | 02:59 PM
  #136
SideStep's Avatar
??? Do these come with retainers? If so, what type???
Thanks
Old Jun 18, 2007 | 03:08 PM
  #137
Yeahdoug's Avatar
Thanks
Sorry they don't , we're working on a package right now, but for retainers you will have to use Comp/Crane/Manley etc. Whatever fits the 918/1218s will fit the 1518s.
Old Jun 18, 2007 | 03:56 PM
  #138
Talking Retainers
Thanks
The Crane part number for the Titanium retainer is 99637-16.
Old Jun 18, 2007 | 04:04 PM
  #139
SideStep's Avatar
Thanks...
Old Jun 18, 2007 | 04:07 PM
  #140
FIVE-O's Avatar
I think it would be easier on all of us if Comp would just release the batch #'s of the bad springs from a year ago...
