what the hell is going on with Comp 918s????
http://web.camaross.com/forums/showthread.php?p=4665206
They were very concerned about how the springs were failing and
equally about making things right for us as end users of the spring.
At this time, it is very evident they are working hard to collect data (springs, opinions, events) and analyze the problem. Keep in mind
they are fighting lots of misinformation on the web and have not yet had adequate time to assess the problem. Though the problem has not been specifically identified, mention of early 2006 springs and indications that fatigue may play a role after 3-4,000 miles was being looked at. It sounded as if they are going to collect more data, analyze the springs, call a few end users, then make an effort to let us all know what they found. While doing this, they actually found time to call end users. Very impressive.
What more could we ask? So, today, I tip my hat to Comp Cams.
For other guys with this problem, I suggest your contact them directly.
You will be glad you did. This has put my mind at ease with this issue completely and would like to express my thanks publicly.
http://www.rinkworks.com/dialect/
Do i need to be concerned here based on what has been happening or would you not worry given I have been golden after 5000 miles so far and my motor although bone stock is boosted to 7 to 8 lbs of boost via a D1SC Procharger?
Comp Cams higher ups contacted me and they were very eager to get my information that led to my 918 spring failure so that the problematic products still out there could be isolated. They clearly admit now that there is a problem with certain batches since more people who have expressed problems have come forward. The first time I contacted Comp regarding this they were clearly on the defense, I think this was because the situation was still relatively new and the busted 918 threads were just beginning.
Comp has provided me with replacement products and made good on the situation, they are even working with the folks who have destroyed their motors as a result of a dropped valve when the faulty springs broke.
Every manufacturer eventually has faulty products that slip out the door. The true measure of an excellent manufacturer is how they remedy these issues and take care of the unsatisfied customer when things like this happen. The comments that some have made regarding Comp not caring or just wanting to screw people are total bunk, thing like that will not happen now days in the age of the internet.
The best thing to do when things like this occur is to document the problem and take pictures of everything to build your case before you contact the manufacturer or post on the boards. It is also best to keep product boxes and receipts. If you seem to have no luck with the first level of customer support then ask for the next higher level of customer support. Manufactures get scammed all the time, this is why they need to have the information stated above in order to proceed with addressing each customers specific problems.
If any customer feels like they are a victim of defective products and feels compelled to post their concerns on any message board, they must contact that manufacturer’s customer service too. Anything less is totally unfair to the manufacturer.
I will admit right now that I did not expect Comp Cams to be as forthcoming and helpful as they were in addressing the two major issues that I have had with their products, they have gone well above anything I would have expected.
Again I am extremely pleased with Comp Cams in helping me out with my specific problems relating to their products. I hope that others have similar positive experiences and will take the time to share them with everyone on the board.
Thanks again to Comp.
Bill
Well i finally got time to swap out my crap 918's to PAC 1518's . Well
the second i pulled my valve covers i noticed the spring pictured below
My batch number was 49826 and i purchased these
918's in october 06' . Here is another victim to add to
the list of broken Comp Cams 918 beehives
I had sent my springs off to COMP CAMS a couple weeks ago and honestly had no expectations about getting anything in return. I talked with them and have given them information about my particular case. I have to say that I am throughly pleased with the compensation that I have received. In my opinion they were more than generous and extremely friendly. It seems as if they are truely trying to put things right with their consumers and they have definitely done right by me. They were extremely fast taking care of me.....amazingly fast really.
I would have to say that it was THE BEST experience I have had while having a problem with a production item from a company. I am very impressed.
Thanks again COMP CAMS!!!!
James Hyde
Red told me if u have a set then just send them to Comp for an upgrade
I already bought PAC 1218's as my cam is only .570 lift
cheers
cheers
