Best block for 427 build
LME, another local builder I did not know about, but found link. Been about 4 yrs since I've built an engine, man alot has been going on since then...
I need big tq. for road race car and alot of romance value (for me,semi oldfart) in a 427 so will probably stick with the 4.125/4.00 setup.
Any reason NOT to use the LS7 block??
Good point..Cant imagine needing to go bigger, BUT we all know how that goes.. Guess its about time to start a top end tread..
But back to one of my original questions..Are there any reliability issues with the dry sleeved blocks? I run all out for 20-30minutes at a time...
If you stick with 4.125x4.00 the LS7 sounds safe.
Does the LS7 block have all of the oil passages plumbed for a LS1 type wet sump oil pump? Will my LS6 heads and FAST90 bolt on?
I'm not planning a 4.125 stroke, but what is the oil problem that I keep hearing about, is that only with strokes over 4.00?
Can't find the 440's on there either. But I have a hard time finding anything on their site. They need to invest in a "Human Factors Engineer" for their web site.
Good question..I believe the LS7 is compatable with wet sump as I dont think everybody that has done one does the dry sump allso but... experts please confirm? Same with LS6 heads..bigger valves needed of course but a bolt on, right?..
Dont know why my quotes are funky but the point is.. best 4.125x4.000 So forgive my misuse of words, I will re-phrase.."Best" for me...
As for the other questions, the LS7 can be used with wet sump and will accomodate any LS based head. You just need to open the chambers to the correct bore size, as you would do with any motor.
The blocks are very similar with the LS7 having doweled steel main caps instead of powdered metal non doweled caps as on the LS2. The caps are not interchangeable between the blocks. The bolt spread is different on the LS7 block.
The Darton dry liner which I did most of the design work on is 5.800" over all length suitable for strokes up to 4.250". Bore size can range from 4.125" to 4.190". So you can choose your stroke for 427" depending on how much you want to spend for a crankshaft. Larger bore = better breathing and shorter stroke = less friction which is why Chevy went with 3.875" stroke and 4.185" bore.
The stock LS7 sleeves will not hold up to racing use. I get several blocks a month in to repair with cracked liners. Most were normally aspirated, not boosted. Some are so badly cracked the only way to save the block is to machine away the stock aluminum wall and install MID wet liners.
Steve
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Could you give me prices for an LS7 block re-sleeved to C6R dimensions, you suppling the block? Also options for a short block built to the same? Would there be much cost difference in a 4.125x4.00 vs the 4.185x3.875 built short blocks?
Thanks,
Joe
