Ms4 Cam In A Heavy Car...........
This is my first post so hopefully I can get some help. I have this stuff on the way- Kooks headers, no cats, DMH cutouts, l.a.p.d. dyno tune, UD pulley. I wanted to do the MS4 cam for max power. I was told by texas speed and LG for the g5x4 it would be a good choice. I spent over an hour on the phone with Al over at L.A.P.D. and he said the cam wasnt the best choice because of the weight of the car. He was rattling off everything from bleed off versus compression. I didnt understand a lot of it. I have always loved huge cams and have seen guys putting up huge numbers. I'm not doing heads or anything else to the car, I'll only have it another 2 years. I will have some sticky 19" rubber to go with it. My question is, for this application and me looking for the fastest car light from light, is this cam a good choice? I'm not looking for something small and am willing to put up with surging etc... (Wont happen with a good tune). I gave al the Cam card today and he says he will study the cylinder pressure, bleed off etc and get back to me with this cam or another idea to meet my goals. Anyone have ideas?
If you want max power something like the MS4 is a good choice. However from what I've read that for primarily street cars many people are happier with a slightly smaller cam with a fatter mid range.FWIW, I'm on a mail order TSP tune and surging is minimal. I'm sure TSP can tune it out once I go in for a dyno tune.
1. Are you planning to remove the motor to flycut the pistons? You may have P/V clearance issues.
2. What are you going to use for valve springs. .650 lift is going to take a lot of spring.
power band felt like 2100ish - 6500, perfect not reving to high for me.
I have a TSP 233/239 and it makes peak HP at 6000-6200. That is perfect for shifting at 6600. If the peak was any higher, you would be spending most of your WOT time on the low side of the power curve. I think you would be real happy with the 233/239. I have no complaints about it. I would not say that it idles smooth, but it runs great at 3000 and up, really comes on at 4000-6500.
Something with agressive lobes as is the MS4 but smaller duration to shift the rpm scale to whats more usable power range for a stockish longblock . Pick the valve events so the cam makes strong torque down low , strong midrange and still pulls hard at 6500-6700 .
CompCams LSK lobes 227/235 .639''/.649'' 110+0lsa {custom ground TSP can grind for you} .
The duration numbers @ .200 are 153/160 , In XE-R lobes its comparable to a 232 / 240 @.050 cam which has 153/161 @ .200 .
Recap: Smaller duration for lowend , agressive lobes so it makes more peak power #'s and 0 advance 110lsa /110icl so it dosen't fall of at 6,500rpm.
Thanks again!
