L-92's w/ forced induction what's wrong?
the easiest way to get it to break the tires loose is reach up and crank the hell out of that **** on the boost controler!!!!!!!!!!!!!
EDIT: PS THIS IS A ******* PAIN IN THE *** TO POST! PS POSTS AREN'T COUNTING! MADE A THREAD ABOUT IT:
https://ls1tech.com/forums/user-support-resources/735044-post-not-counting-continued.html
https://ls1tech.com/forums/showthread.php?t=735044
In my opinion the cam is too small for the L92 heads. Even though it is a turbo application, it should probably still be bigger. Also the compression is pretty low, especially for the low boost you are running. If you want to run only 6 lbs the compression can be 9.5-1, and if you want to run pump gas and like 10-12 lbs then it needs to be around 9.0-1.
Rick LeBlanc
Livernois Motorsports
Rick LeBlanc
Where is the timing in relation to the previous setup? Where was the compression in the previous setup?
Robin
Sounds like you are trying to keep the exhaust velocity up. With your cubic inches you should be able to run a larger cam (like Rick said)
I playe with a bunch of cams with my old 76mm years ago. The wide lobe sep helped reduce intake contamination. But the pressure on the exhaust side dictated where the power would fall off.
Those heads flow very well, no need to have a higher duration in my opinion.
Robin
My old motor was stock with 6 psi so compression was alot higher but I would think the extra cubes of the new motor would make up for it.
I just think a motor that should be cranking out at least 600rwhp at 15psi should be alot stronger at 6psi.
I have not brought it to the dyno yet but it doesn't take a genius to know this thing is slow. I am just really disappointed thus far and am hoping to find out why and fix it.
Air fuel right know is rich at 11.0 to 1.
Ofcourse the car wants more timing, youre only running 6psi with no compression... turn the boost up
-Geoff
Collect some IMP and EMP data.
I have a feeling your going to hit a wall with making boost fiarly quickly.
