L92 head 427 makes 700HP n/a!
I do have photos of the work done to the heads and intake for those interested. I'm trying to get a graph posted, but I've never had much success doing it before.
Brian
HiTech Motorsport
What was the static CR out of curiosity and I assume you will be posting a gragh with the overlay of both intakes?
Thanks and congrats on the results....
Tony
I believe the compression ratio is about 12:1 - my compression tests showed 210 PSI cranking, which is borderline for pump gas around here, but I tested it on Power 110 race fuel since the engine has no knock sensors.
I am new to posting images but I have my web guy putting up graphs on our web site and will make a post directing to them.... should be up sometime Tues. the 26th.
Becausing the block was a 6.0 iron instead of an LS2, it has no bay to bay windows in the main webs or passages above the pan rail which I believe would be worth even more power since the engine is so big and has only a stock F-car oil pan on it.
Headers used were our dyno units with 1 3/4"- 1 7/8" primaries to 3 1/2" collectors.
D.J.
I think I know where the motor came from. Did the pulls happen with the sheetmetal intake that it came with?? Or did you make a new one??
I believe that engine was put together with the intention of running e-85.
DISCLAIMER: IF this is not the engine from another shop that I am thinking of, please disregard all comments.
The engine made peak power with the sheet metal intake at 6900 RPM with peak torque at 5300 RPM. With the L-76 intake, peaks occured at 6300 and 4900 RPM respectively.
Brian
HiTech Motorsport
