L92 head 427 makes 700HP n/a!
#81
Ok i am running Comp SP and RP solid roller lobes with GM Cadillac race hydraulic lifters. The lobes are 252* and 260*@.050"on a 111* LSA the rockers are stock and net lift is .660"/.647" My pushrods are .080" 5/16's My springs are the Ferrea duals with 170 seat and 480 open lbs. You realli think thats enough spring to deflect these pushrods?
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
#82
Yes, the 5/16" pushrods are inadequate for your app. A set of 3/8" x .080" wall pushrods will work wonders as will modifying the rockers w/ the Harland Sharp bearing and trunion upgrade. With these parts (along with an unspecified beehive spring) I have been able to spin my stock eliminator engines to 8200+ without valve float.
#83
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
oK WHAT RPM are you turning with no spring surge or seat bounce?
#84
HELP?
