lsx block
Old Jul 18, 2007 | 11:24 PM
transam600hp's Avatar
Default lsx block
i need a little help i am needing to rebuild my motor in my 99 trans am that is procharged f-1 i was looking at the new lsx block and woundering if it is worth the money and is it good for a s/c with a ci of 427. thats what it would be with my crank and rods out of my 383. i am looking to get around 1000hp with a good set up.
any and all comment and opions are welcomed thanks
Old Jul 19, 2007 | 01:44 AM
Mr.MartyStone's Avatar
why not just sell your 383 complete and then buy the 427 or 454?
Marty
Old Jul 19, 2007 | 02:45 AM
i am reuseing some of the parts from the 383. heads, crank, rods, maybe cam
with my crank and rods from the 383 i can use them to make a 427 with the lsx block.
isnt it hard to feed a 454?
Old Jul 19, 2007 | 11:15 AM
snketr's Avatar
Why not just save yourself aournd 3k and put new pistons in your 383?
Old Jul 19, 2007 | 01:37 PM
You're going to spend more in the long run that way. But hey if you want less for more then go right ahead.
Marty
Old Jul 19, 2007 | 01:50 PM
Stang's Bane's Avatar
Yeah, it takes alot of air to feed a 454, but that F1 can do it
Old Jul 19, 2007 | 04:42 PM
so what your saying is that the 454 coast just as much and that my f-1 will be able to feed it.. i am going to look into it also
we are looking at a builder in ohio i think that dose all of prochargers build ups i thinks its called extreme performace or something likr that. they said that i should use the new world block?
Old Jul 19, 2007 | 06:26 PM
The short block might cost 7000. you could probably sell your motor for 3500 or so. If you were to reuse your stock parts you would be limited to around a 427 or 440. Plus you would still have the price of the block (2100) plus pistons and rings (800) and fasteners (250 or so) plus machining (750 or so).
And if you were to go with a built shortblock you would have a warranty on all the components from the company that sold you the shortblock vs. having warranty from one company for machine work, one for pistons, one for rods, etc etc. See how it all adds up now?
Marty
Old Jul 21, 2007 | 05:02 PM
Quickin's Avatar
Marty
There's only two shops that I know of in this country that will warranty a "forced induction" engine........NRE and LPE. LPE rips people off and charges 2-3 times what the set-up is worth, so in essence you already pay for a couple set-ups. NRE doesn't charge any more than the set-up is worth, but they build solid set-ups so they can offer a warranty on a 1,850 hp TT 427 and a 2,300 hp TT 454 LSX blocked engine.
Old Jul 21, 2007 | 05:04 PM
Quickin's Avatar
If 1,000 hp is all you want, a World block is complete waste of cash. Any LSx block will do. If you want to have gobbs of reliablity and longevity, use the GM LSX iron block, its the king. $1,995.00 is cheap for that bad boy.
Old Jul 21, 2007 | 09:37 PM
Tom@SpeedInc's Avatar
We finish a procharged LSX block build in a WS6 with a couple weeks ago, everythng bolted up nicely.
What your going to find out using old parts, Unless their Lunati or Oliver rods they may not be worthwhile refurbishing, we had a set of compstar rods rebuilt with new callies spec ARP 2000 bolts and for a couple extra dollars could have had brand new CompStar H beams.
Old Jul 22, 2007 | 02:57 AM
the crank and rods are eagle and there are nothing wrong with them. is eagle going to hold that kind of power? i am only going for 1000hp still want the car to be streetable. no tralier queen.lol
Old Jul 22, 2007 | 10:24 AM
Quickin's Avatar
Chinese made, I wouldn't want that in a 1,000 hp set-up. There have been failures of Eagle cranks, I've never heard of the top American made cranks breaking. And, yes, some cranks sold by other American companies are macde in China as well, but not the top of the line cranks.
Katech had a stockpile of Cola cranks they were selling off, see if they still have one. Probably the best crank ever made.
Maybe Eagle is better now????????????
Old Jul 22, 2007 | 01:09 PM
NA$TY-TA's Avatar
FYI ive made over 1100rwhp with Eagle rods and a stock crank...
The stock crank was starting to flex at those power levels...
There is nothing wrong with using eagle parts to make big power... they have proved they can do it over and over again...
An LSX Block is a waste of cash if your not going to go with 6 Bolt heads.
Thats the whole point of going with it... more clamping force.
Now the $1995 for the LSX block is cheap but around $3500 for the 6 Bolt ETP heads isnt....
The World set-up is $4.5k for the block and $2364 for the heads.
Old Jul 22, 2007 | 07:00 PM
LOTS of misinformation in this post. The eagle stuff is fine at 1000hp.
Marty
Old Jul 22, 2007 | 11:49 PM
what info do you need to know?
