LS7 Pistons
http://www.performancecarfactory.com...2_itemId=53649
We are each building our own flavour of the GM LS7 using LS7 block, heads and intake. Forged internals will hopefully keep the lower end together.
We are also making appropriate changes/upgrades to the valve train to keep the gremlins out. Other than LS7 1.8 rockers - anyone knwo what the other rocker options are for GM LS7 heads?
Just talked to Jason and their pistons are 159.00 ea, plus 35.00 ea for pins.
WTF? 1552.00 for a set of pistons. That is insane!
We are not a piston warehouse. We make short runs to supply the LS7s we build. Thats what they cost. The pins I quoted you are DLC coated. DLC coating is very expensive. Before coating, the pin is only $6.
It is going to be hard to find. The only way to get the piston off the rod is to drill out the pin clip.
I was going to go with Wiseco.. I can't have my "buddy" get better pistons than I am getting.. but I am trying to determine why they would be better and what advantage they are going to be giving him?
They are slightly lighter than stock. I don't know what the Weisco weighs. Our pistons have accumulator grooves, detonation bands and they are hardcoat anodized. You're getting a piston designed by the same company that worked with GM to develop the LS7. We have them in 9:1, 10.4:1, 11:1, 12:1, and 14:1 compression, 6.067 and 6.100 rod length, 4032 and 2618 material.
Streetability, smooth idling and manners are not a concern - I just want the baddest meanest nastiest LS7 using the GM LS7 heads, LS7 intake and LS7 throttle body.
No offense Jason. Katech makes some of the nicest products in the business and supplies to a specialized crowd. R&D is expensive, thus the parts are going to be expensive. Wish I could afford a set, but my budget is a little tight considering I am building an LS7 from scratch. =)
GM's stage 3. It has incredible valvetrain control considering how agressive it is. Or stay tuned for more Katech cams.
