lsx 930hp
I dont think so man....I've seen the welded on boses and thse aren't them..Are you saying you know this for a fact?
Matter of fact i'd bet money that they are the new heads....Look at the castings!!!!The look nothing like a c5r head..
From the page.
From the page.
lol well if thats the case the bosses look alot better than these...I still think the are the new castings..
https://ls1tech.com/forums/forced-induction/688160-6-bolt-afr-heads.html
First the bosses were welded to new castings prior to heat treat or machining. They started as C5R castings.
The "experimental" head was the head that we cut and ported. We used that head for development. 1 Port was cut, another hand ported and another CNC'd.
I am currently switching to a revised set of C5R heads. They have larger cumbustion chambers and wider intake bolt spacing as well as other small changes. Like the C5R heads they are not optimum for our large cubic inch nitrous combination. These heads were cast with the additional bolt bosses. This head will probably not be released.
GMPP is currently working on a version much better suited for large cubic inch LSX engines. I am sorry that I cannot discuss that head at this time.
I cannot wait to see these heads!
Robin
Robin
So Robin...... any idea on the ETA for the GMPP 6 bolt heads????
Kyle
Robin
D.J.
