build a 408 or buy one?
Man, I still think in terms of small and big block chevy. They built the same motor forever, then started spitting out new engines left and right. I'll get it eventually.
Now I just have to figure out which stroker I need.
Iron 413 - $3549.95
Aluminum 413 - $4349.95
....o'well its on charge gess I'll try it tomm LOL!!! Iron 413 - $3549.95
We addressed that issue before we ever started building the longer stroke engines. We use special ring packs that controls the oil better than the standard ring packs. We also use a smaller ring stack on the super long arm cranks to make sure there are no oiling issues.
So far we have had no oil burners with any of the El Toro engines.
Not trying to be argumentative. But you came into the discussion thread with an advertisement and left out some factors as if they don't exist. Nothing wrong with advertising, but I don't think it's very honest of you to present one side of the story and not the other. The nice guy role is great, but a nice guy presents an entire story. So it would be more like this:
"Even though nobody is having issues with an iron 408ci engine with a 4.030" bore and 4" stroke, we have an option. It has a few more cubes but probably won't make any more power since it's made with more stroke than bore. Now in theory the excess bore will allow the cylinder walls to distort. But in reality nobody is having that issue. But if you think you'll make more power than anybody in the history of the iron 408, we have a great alternative for you."
Not to be argumentative, but alot of the "perfect square" hype that people are reading on the internet is just that....hype.
As for the potential oil consumption concerns: Numerous reputable builders around here have agreed that with the right ring package, a 4.1" stroke on these engines is not a problem.
what heads & cam are you running?
