LME built LSX "440" , 6 Bolt heads and a Kenne Bell 2.8 !!!
Old Sep 8, 2007 | 01:09 AM
Jeff@TotalPerformanceEng's Avatar
With my AFR 225's and 16psi (about 16000rpm compressor speed) we got a little over 800rwhp on pump gas. But we were pressing the limits of the tune pretty hard..
We were running a Nick Williams 90mm TB. But we also had him custom make us a 100mm one as well, and we only saw about 1/2" less vacuum.
Yes the measurement was taken in between theTB and the rotors.
The reason I'm fairly confident its the intake and NOT the S/C is because it happened on both the 2.6 AND 2.8 I tested. The boost loss was the same.
Originally Posted by HOWQUICK
we went to 800rwhp with ETP 245cc Cathederals @14psi with 3.3 Whipple at 14.5krpm compressor speed on 402".
ditto.
Typically we see boost fall where the engine has best volume efficiency, as to be expected with PD, and then increase as the engine stops wanting to move air unless the compressor is too small and boost continues to fall.
On the 511" Top Alky engines with 4.9L PSI driven at 108% over crank speed we see the engine stop moving air at 9000+ rpm and the boost increase exponentially from this point.
Valcuum at the TB before the rotor? What size TB did you have?
Old Sep 8, 2007 | 01:21 AM
HOWQUICK's Avatar
vacuum before the SC is never going to lead to compressor efficency. I have seen in increase in boost of 3psi by removing a restriction less than yours. Pump gas and road tune here.
Regardless 440" is going to need a lot more SC than 2.8L regardless of who made the rotors. If they want to see some real boost in the thing. From what I have seen it will just start making super heated air. Would be a happy dyno to show 1000rwhp from what we see here.
Can't understand why anyone would want 6 gears behind 440" of PD boosted LS unless they are going to run it on the Salt Lakes or something using them as overdrives.
Old Sep 8, 2007 | 02:01 PM
Thats EXACTLY what i'm saying. You want to see as little vacuum as possible in the intake track. Had we been able to re-configure the intake itself, we would have been able to pull more power with the same setup. But due to the intake restriction, the more boost we pulled through the blower, the higher the vacuum in the intake track.
I think the 2.8H will be able to hold up with the 440. I've seen the the data between the 2 blowers, and although 3.3 is bigger than 2.8, the efficiency of the blower and manifold design is whats important. (plus obviously the S/C itself)
Will it have a tough time?? Oh Yea.. Will it be maxxed out?? Hell yes it will.
But I have a feeling that if boost is kept at a respectable level, and the manifold is as efficient as I think it will be, it should be a monster..
IMHO..
Old Sep 8, 2007 | 03:40 PM
datsbad's Avatar
I am going to just sit back and take in everyones info and let you guys argue it out , When it is being assembled I will show a few pics. Thanks
Old Sep 8, 2007 | 03:54 PM
beardWS6's Avatar
Thats why I like my Beck intake. Can`t wait to I put a blower on my set-up one day!
Old Sep 9, 2007 | 04:55 AM
Adam_346's Avatar
sounds sick!
Old Sep 10, 2007 | 01:48 AM
No arguing here....Just a gentlemanly conversation...
Please PM me some pics when you get it done. And although I am sure you have some very compitant builders, if you need any advice on some prior experience with this S/C, please dont hesitate to give me a shout..
I literaly have hundreds upon hundreds of hours worth of R&D time into the KB 2.8/LS motor configuration..
More time than I care to admit.
Old Sep 10, 2007 | 02:59 AM
HOWQUICK's Avatar
Beck intake won't help with the problem HP is on about. The problem is pre SC not post.
same here.
just passing on some experience.
I don't reckon you need 6 gears with the steam a big inch PD car will have.....
Old Sep 10, 2007 | 08:01 AM
CHRISPY's Avatar
Have you guys talked to KB? That CFM produced on motor by that displacement and head flow sounds AWFULLY high for that little compressor.
I bet you are compressor limited with that setup. Pulley the thing to max impeller speed and see where the boost shakes out...
Old Sep 10, 2007 | 09:31 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I'm guessing he meant centrifugal.
Old Dec 19, 2013 | 11:39 PM
bmf5150's Avatar
I wish some one built after market ls7 based intake for the kenne bell
