What spark plugs & motor oil for a 416 ci. 13:1 race engine?
#121
I LOVE rotella oil. As a matter of fact, I just put the first gallon in my new motor about an hour ago.
This is how I do it for the first 150 miles.
1) Fire motor for 10-15 minutes, let oil temps come up and cooling stabalize. Drain oil/filter while its still hot. Replace oil/filter
2) Fire motor w/medium accell and decel. Fluctuate loads for 15-20 minutes. Change oil (Not filter)
3) Do all part throttle tuning. 50-75 miles. Change oil/filter
4) Do all WOT heavy load tuning. 100 miles or so. Change oil and filter.
I dont switch to synthetic for at least 1500-2000 miles.
Of course, this is on a street car. I'm not really sure how racers do it
#122
8 second mod
then i change to a 20w 50 vr1 after that, and i change it after every track visit
#123
FYI
For all of the 15w40 diesel oil uses the new CJ rated oil mirrors the new SM rated oils.
So if you think your getting a better additive package by running the diesel oils you might want to rethink that one
#125
I am just saying that if you are buying the currend diesel oil thinking that you are getting a better anti wear add pack then you should look at the new diesel oil specs.
At one time you would have been getting a better oil but not now.
Any oil that meets the current API engine service classification has less anti wear additives and should be avoided.
#126
Here is what I have learned by calling SDPC (my 416 shortblock) and Valvoline tech support:
According to SDPC who built my engine the first 5K miles are with non-synthetic containing ZDDP and then for the rest of the engines life synthetic but it also must contain ZDDP.
Rotella and Valvoline Racing oil are OK for the first 5K
There are two Valvolines. The NFS (not for street) and VR1. Both have the proper levels of ZDDP. I called Valvoline and asked what the difference was and why the NFS was $10/Qt. while the VR1 was less than $5/Qt. Answer NFS is good only for 500 miles and made in limited quantities. Also said as did SDPC that the VR1 was good for breakin.
Valvoline also has a synthetic racing oil with ZDDP when its time to go synthetic.
SDPC recommends either Rotella 15/40 or Valvoline 10/30. Valvoline also comes in 15/20
Is anybody using 10/30?? Seems like 20/50 would be safer?????
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
DH
