My LSX 454 Buildup (Pics in side) & Tips I learned along they way!
#181
I've been tinkering with the car some more. I just reinstalled the A/c into it, and that aggravated my crappy idling. Also even after the dyno tune it had some surging or bucking at low throttle or no throttle at lower Rpm's. I have been fighting the throttle body for weeks now. If I screw the throttle open far enough to bring the Iac counts down to a reasonable level, the tps reads 2-4% open even though there is no throttle.
I was reading the post; Stop Drilling those Throttlebodys
https://ls1tech.com/forums/pcm-diagnostics-tuning/177230-stop-drilling-those-tbs-fix-stalling-without-computer-tuning.html
So To fix my problem I had to drill the Throttle body. I ended up with a 3/8" Hole in the blade. This brought the Iac steps down to a reasonable level, I show about 5-10 Iac steps at hot idle no a/c, and about 100 Iac steps with the A/c on. And WOW did that make a incredible difference in the driveability and stability of the car!! Day and night difference, It has no bucking or surging anymore!!!!
So with that big of a engine and cam, and a small throttle body it needs a hole. No amount of resetting the tps will fix it if the blade is open so far that the tps dose not go back to zero.
#183
If the budget is there I will be doing a Complete Ls7 Ported top end. Heads, intake, throttle body, maf, ect...
Either way It will need another Dyno tune!! With some bigger number I Hope!!
I still have to fix my dana 60 leak. I just ordered a new gasket and oil so that should do it. It was also leaking from the case but I have that fixed now.
Drove it today And I think my pinion angle is off. It vibrates at anything over 60MPH on or off the throttle. Dose that sound like pinion angle or a drive shaft that needs balancing???
#184
Got the car back today, it drives straight!!! I measured the pinion angle and it was only about .5-1 Degree so I bumped it to 2-2.5 degrees, I will give that a try this weekend.
#185
[QUOTE=MPHmotorsports;7872810] ya i was just going to say it looks like you have LS1 studs in that thing
Originally Posted by 1Hotbird
I'm at a stand still with the assembly of the engine, Weds night I reolized the head bolts would not work
So thursday I ordered the ARP LSX head bolt kit and instructed them to overnight ship them. Friday No Bolts
I called and they said they shiped them saturday special They never showed up
So now it will probably be the weekend after next when I get it in and running.
Andrew..... looking good.
Sorry about the bolts. I will check to see why they didn't arrive first thing tomorrow morning.
Of course I will call you once I get it straightened out.
To add a few more things. Andrew and I put together a setup that will hopefully work nicely for now and even better for a future top end. We used a piston that works for a 15 degree head or a 12 degree head that way we can do a LS7 top end in the future. We also specked a cam that will hopefully work ok now but really come alive with the LS7 style heads and the 1.8 rocker's. A lot of little things to think of when trying to put it together for now but have room to grow for later.
Also the headers are actually American Racing 1 7/8" race headers.
I am looking forward to seeing the results.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
#186
old thread I know but was a new top end ever installed?? I read through all the pages and was hoping for some new numbers with the better top end. Really great numbers considering the intake and heads!!
