4.030 x 4.00 on an ls2?
Old Oct 4, 2007 | 09:00 PM
itspossible01's Avatar
Default 4.030 x 4.00 on an ls2?
Any issues with going 4.030 x 4.00 on an ls2 for a 408?
Old Oct 4, 2007 | 10:28 PM
Randy WS6's Avatar
I have my LS2 bored 4.030" but i use a 4.100" stroke ,runs grate 418cid.
Old Oct 5, 2007 | 09:37 AM
merriman44's Avatar
How does this work without a resleeve? I thought the ls2 can only be bored .020 over?
Old Oct 5, 2007 | 11:21 AM
Randy WS6's Avatar
Well, Ive had mine bored .030" for a year now and also run a 250 shot of n.o.s. and with 12.5.1 compression and not once have i had any problems. MrEracer (Shirl Dickey) does it all the time,He's the one that help me with mine ,here on LS1 Tech .you can do a search on him to fine out more a bout it.
Old Oct 5, 2007 | 12:35 PM
No oil problems? How often do you spray?
Old Oct 5, 2007 | 12:39 PM
Did he build / assemble the engine or just tell you how to do it?
Old Oct 5, 2007 | 12:43 PM
Or maybe the better question is what do you have to do special to run this setup....? I found your thread:
https://ls1tech.com/forums/showthrea...18#post3988820
Looks like you got custom pistons from Ross Pistons for $800 that were clearanced for the reluctor wheel and used the stock 4.1 Eagle crank and 6.125 rods. Were there any other "special" things that had be done....ie at assembly? Who bored your block for you?
Old Oct 5, 2007 | 04:56 PM
Randy WS6's Avatar
He told me what to look for in clearancing , like rod bolts to block clearance and rod bolts to windage tray and so on. ,and yes i build my own engines. I worked with Ross to design me a set of pistons for the 4.100" stroke crank to clear the piston to counter weights and piston to deck height ,there is a lot of clearance problem with the 4.100" stroke and higher. You can see some of the engine build in my sig. My next motor build is going to be a 433cid.
Old Oct 5, 2007 | 06:54 PM
Any information on the pistons would be appreciated. I am going in that direction but with a lower compression ratio. PMd you.
