Max bore on L92 block??
Old Oct 16, 2007 | 03:16 PM
GTFORMULA's Avatar
Default Max bore on L92 block??
I have heard of 0.030 over on LS2 blocks. Does anyone know if the L92 block is capable of being bored ? If so how much while still retaining strength ? This will be used on N/A or small shot of N2O. Thanks.
Old Oct 17, 2007 | 12:53 PM
GTFORMULA's Avatar
to the top
Old Oct 17, 2007 | 06:40 PM
Wnts2Go10O's Avatar
there are a couple people running 4.1 bores i think.. its very iffy and requires it be sonic tested but its being done.
Old Oct 17, 2007 | 07:32 PM
GTFORMULA's Avatar
I would appreciate anymore info. I would like to get some of the big builders to chime in too.
Old Oct 17, 2007 | 07:36 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
What the hell do you plan on putting this in? I saw you were selling all those mustang parts.... Hmmm...
Old Oct 17, 2007 | 08:19 PM
GTFORMULA's Avatar
HHMMMMMM. I am thinking of boring an L92 block out, putting in bigger studs, and topping it off with TSP's new ported LS7 heads. It might go in my 2900# mustang. This will be my daily driver / street race car. With 150-200 shot it should be a very potent package.
Old Oct 19, 2007 | 06:38 AM
GTFORMULA's Avatar
to the top. Need more info.
Old Oct 19, 2007 | 10:55 AM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
That's something I've been really wanting to try. I'd like to see if the l92 on a 4.100 bore would be possible with the LS7 head.
Jason
Old Oct 19, 2007 | 03:47 PM
GTFORMULA's Avatar
Well you guys would be the ones to see if it would work. I would like to know for sure that combo would work. As far as the chamber hanging over on the deck surface. I just want to make sure that the valves and chamber would work on that bore.
Can the L92 be bored to a 4.100?????
Old Oct 19, 2007 | 11:32 PM
zssman's Avatar
Jason
what would the cubes be with a 4in stroke. Do it and let us know. possible budget big cubes. Thanks.
Old Oct 20, 2007 | 07:41 AM
GTFORMULA's Avatar
I would like to do it but I need to know for sure if the sleeve is thick enough to go 4.100. I would also put in a 4.1 stroke. It would be 433 cid according to a cid calculator.
Old Oct 21, 2007 | 07:33 AM
GTFORMULA's Avatar
to the top
Old Oct 21, 2007 | 09:49 AM
gspotfinder's Avatar
per the gm service manual the l92 block can be bored out .020 which they also offer piston in that bore which would be 4.085, anything else has yet to be determined?? it would probably require having it machined to accept bigger sleeves
Old Oct 21, 2007 | 03:58 PM
GTFORMULA's Avatar
I know GM will not say to bore it over much. I am looking for some bigger shops that have sonic test some of these to see.
Where is SDPC, TSP, speed inc., W2W, and all these other guys.
Old Oct 21, 2007 | 06:18 PM
LSInnovations's Avatar
Try calling them
Old Oct 21, 2007 | 06:45 PM
GTFORMULA's Avatar
I know i could call them. I figured like everyone else on this board that posts questions, I would post up and some of them would answer.
Old Oct 21, 2007 | 07:20 PM
Wnts2Go10O's Avatar
someone on this board did build a 4.1 bore l92. where the post is, i couldnt tell ya
Old Oct 22, 2007 | 02:29 PM
GTFORMULA's Avatar
to the top
Old Oct 22, 2007 | 02:37 PM
Stang's Bane's Avatar
4.1 bore with a 4" stroke is 422 ci.
FWIW. there are ways to make the ls7 heads fit on a smaller bore.....
Old Oct 22, 2007 | 03:07 PM
Mr.MartyStone's Avatar
Psssst, call Shirl Dickey.
Marty
