Where can i find Stock LS2 or Forged Rods that are .927 Wrist pin dia
Hey i just got a question for anyone out there who can turn me in the right direction .. ok i have a Stock Piston of a 4.000 bore .. with a .943 Wrist pin Dia. Well now i had a problem with the engine so im tearing it all apart cause i chilled piston #7 , so i ordered all new Pistons , Which are Diamond Forged Flattop Pistons with 2 valve Relief .. But they are a 4.005 bore .. with a .927 wrist Pin Dia.. now heres the Problem .. I gotta take it to a machine shop and have them Hone the Block out so i can use these pistons .. SO now i cant use my Stock Rods since my piston are a .927 Wrist pin Dia. and my Rod is a .943 . SO now my question is Where can i FInd a rod , i dont care if they are H beim or I beim .. I need a 6.098 Rod Length with a .927 wrist Pin dia, with the Stock Crank Dia For the LS2 Crank .. in the 2005 Ls2 Corvette Motor .. Where Can i find these Rods at ? can Someone help me out here ? or will i have to Sell the pistons i have and Reorder the new pistons with a .943 Wrist pin Dia ? I would Appriciate any help , THANKS MUCH ..
OWN3D BY MY PROF!
First off stock pins are .945. Secondly pretty much all aftermarket rods are for a .927 pin.
Speed Inc (a sponsor) carries these. Ignore the arrow I used that for another thread I made.
You're going to want the ones that say Scat H Beam - stock length - for .927 pin. I'd also suggest getting the ones with the ARP 2000 rod bolts for some added strength if you plan on using nitrous or something else down the road.
WHats the Website
What is the Website i can order these Rods on ? and these will work with the stock Crank ? The Price does not include Rod Bearings doe it ? and does the Wrist pin in the Rod include a press in bearing in it ? thanks much man..
that is our www.speedinc.com
I have a set of scat I beams .927 pin rods in stock price is $249 the rods are press pin
Just as beaflag vonRathburg mentioned, H beam with with arp bolts is the way to go, Callies compstar also makes a 6.100 rod with .927 pins they are also bushed for floating pins, pm or email for details on them.
The price has changed on the I beam .944 pin ones, new price is $299 shipped within lower 48.
it sucks when prices go up, they're imported product.
LS1TECH & Trucks Sponsor
We've got a couple sets in stock as well
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
About the Scat H beam Stock lenght - for .927 pin
Are the Scat H beam Stock lenght Rods for a .927 pin Floating in the Rod ? For $449.00 Cause thats would i would Rather have considered to the Pressed pin Granted the Pins in the Stock pistons are Pressed in the PIstons . The Stock pistons pins are pressed into the pistons . but the 4.005 Diamond Forged Pistons i have now are just Floating with C clips to go in to each end of the piston to keep the pin is , that should be a problem should it ? And Do the Scat H beim stock lenght - for a .927 pin will they fit tight on my .927 pin now or will they float around inbetween the piston ?
How can i Order the Scat H Beam -Stock Lenght rod for an Ls2- for a .927 Wrist pin ? I need to order these 8 Rods and get them ASAP , Next Day if possible , Will they come with Rod Bolts ? and will they Come with Rod Bearings ? LEt me know ASAP cause if not i need to get some Rod Bearings to Fit these Rods for the Stock Crank too , PLEASE SOMEONE HELP ME OUT ASAP .. thanks alot .. Or if Anyone can help me Call my Celly phone 614-348-0087 Thanks or E-mail me DrewDaitalianone@yahoo.com . thanks
About stock LS2 Rods with a .945 Pin Dia Can i make it a .927
Do they MAKE fittings / Bushings or somthing to take my Stock Connecting Rod From a .945 Wrist pin Dia to a .927 , if so can somone help me out here PLEASE a Website or someone who makes them .. i know its a pressed fitting ..
Get those SCAT H-beam 6.100 rods for a .927 pin bore. I'm looking at getting the same set. I have a buddy that has the same rods in his 402 except they are a 6.125". They are good rods for the $$$. I also need a 6.100 rod with a .927" floating pin for my Wiseco's
AT MINIMUM.. get the I-beams. Don't screw around with the stock rods... You can have the stock rods bushed for a floating pin... But WHY? and you will spend $ on the stock ones. For $249 buy the SCATs
